Is your glovebox like this?
Pix Doc
Post by Pix Doc »
Or do I need a trip to the dealer?
Base 2-Tone Salsa -- Photos of my Vibe and Mods HERE-----> http://www.pbase.com/pixdoc/vibe_picsCustom ExhaustEnkei MM2 (Anthracite) WheelsViper Alarm W/ remote startSilverstarsJVC KD-SX780 Head Unit - Kenwood KFC-1689ie speakers - Apple iPodS2000 Honda Antenna - Bumper ProtectorN0 Badges or Luggage CrossbarsMMMMMMM......SAAALSA
ragingfish
Re: Is your glovebox like this? (Pix Doc)
Post by ragingfish »
Mine definitely closes flush with the dash...might've warped from the heat? Definitely needs an adjustment (or replacement).
2009 PONTIAC G8
msmyer
Re: Is your glovebox like this? (ragingfish)
Post by msmyer »
quote:Mine definitely closes flush with the dash....Mine too!
‘03 Vibe with 317k and still going.............................
Other Mods: Sony X-Plod Headunit & Reflective White GVC decalMy Car at Cardomain.com... http://www.cardomain.com/id/msmyer
ragingfish
Re: Is your glovebox like this? (silverawd26)
IE is being troublesome again. Could someone's avatar be corrupted?I have to use Netscape to see any pictures from Pix Doc...
2009 PONTIAC G8
Geo
Post by Geo »
I SWEAR IT IS NOT ME!!!!!!!!!!!!!!!!!!>.>(And everything works 100% fine on my MAC! )To answer question: My glovebox isn't like that. Get it checked out.
BADGER PRIDE
NSimkins
Global Moderator
Re: Is your glovebox like this? (Craven Morehead)
Post by NSimkins »
There was a Question Mark (?) in the filename which probably confused some browsers (worked ok initially for me).I've corrected the initial post and the one by silverawd26. It should be all good now!
Pix Doc
Post by Pix Doc »
I'll change it to a stock one. It shows up fine on my Mac!?The picture of the glovebox makes it look worse than it is, but I will bring it in. Thanks for the feedback.
Pix Doc
Is my Avitar Showing? (tee hee)
Post by Pix Doc »
Hope it works.
Pix Doc
Re: Is my Avitar Showing? (silverawd26)
Post by Pix Doc »
Thats Bizzarro.
Pix Doc
Now yours and ragefish is GONE!?
Post by Pix Doc »
What the...
Pix Doc
Re: Now yours and ragefish is GONE!? (silverawd26)
Post by Pix Doc »
I saw them all untill I changed Mine. Also some of the emoticons are missing at the bottom of the posting section.
Pix Doc
Re: Now yours and ragefish is GONE!? (Pix Doc)
Post by Pix Doc »
Oh well, Off to bed for this Baby. I will check when I get to work tomorrow.
cohocarl
Re: Is my Avitar Showing? (Pix Doc)
Post by cohocarl »
quote:Thats Bizzarro.Yes it is working fine on my end now also. For some reason, it would "stall" I.E. on alot of memeber's machines and not let most of the graphics load. Once we accessed a post that did this, we would have to completely shut down I.E. because even other web pages we would visit after that (not only genvibe) would stall out. (????????)Anyways, thanks for changing your avatar. I don't know if it's the format or what that works on a Mac and not on others, or what, but it is frustrating.quote:Think Nick has to get on this one... I think Microsoft needs to get on this one....Thanks again,Carl
Geo
Post by Geo »
Pix Doc: Do you use Safari?I think there is a problem with the way Safari or even other Mac browsers upload the avatars to GenVibe itself, but then again, the images work fine on other Macs as well as some PC browsers.MS needs to get its head outta its rear and make something that works.
BADGER PRIDE
Pix Doc
Re: Now yours and ragefish is GONE!? (Geo)
Post by Pix Doc »
Well I am checking this from my work PC that has an ancient version of IE. I am leaving in a few to go home and I will re-chck it there, but everyone is accounted for on this machine.
ChinaThong
Post by ChinaThong »
I don't think it is a major problem to fix your glove box.The first time I checked my a/c filter (which is located behind the glovebox), I had some problems putting it back in correctly. I now know how to do it without unhooking the door. But on that 1st time, I had accidentally pulled the door off of the hinges, and it looked just like your picture when I tried to close it. After a couple of minutes of playing with it, I fixed it myself.
Pix Doc
Re: Is your glovebox like this? (ChinaThong)
Post by Pix Doc »
LOL I guess I should have tried that first. It may have taken more time to take the photos and post them than it would have taken to fix it! I will mess with it on my next day off. Thanks for the suggestion.
Pix Doc
Post by Pix Doc »
This is the FIRST thing that I brought to the dealer that mostly fixed.I say mostly because now I have to make sure I push it tightly into pace or it falls open. GM Service SUX. I shudda gotta Matrix
Vibe Rater
Post by Vibe Rater »
Unacceptable. You probably have a misshapen glove box door, caused by poor molding. If they try to cool the plastic too fast at the vendor, it will warp or bend. If the dumbass service department has tried evreything to adjust the door, and it still doesn't fit right, demand a new door. It's a easy, quick, cheap fix and shouldn't be a problem, but this is GM we're talking about here.
ragingfish
Try a different dealer Pix Doc.Some dealers act as if it's an insult to them to be fixing not mechanical things. Other dealers value their customers, and will go out of their way to make sure your happy, and will fix whatever you tell them to.Maybe you just need to try your luck at another dealer...But sorry for the unsuccessful service visit.
2009 PONTIAC G8
Pix Doc
Post by Pix Doc »
They are installing a new Shifter Compartment door that keeps flopping open and the trim around the electric windows/locks that had a gouge in it when I got the car. I will let you know how it goes on my next visit...
