Finally got the gaskets, and went ahead with replacing them.insulation and cover offclose up on manifoldhoses offthrottle body offmanifold offdirty gasketcylinder 4, sludge in intake chamberscylinder 3cylinder 2intake manifoldsludge in manifoldlower manifoldoil in manifoldupper manifoldoil in upper manifoldold gasketsnew gaskets, ordered through O'reillys, Fel-pro brandcleaned upper manifoldcleaned manifoldgasket sealantcleaned valve chambersGot everything put back together, runs great.also flushed the coolant, adjusted the parking brake, and stopped the rear brakes from squealing
Nice write up and pics. Glad everything is running good. Great job.Did this solve your hot start problem? If it did post up in that thread too as solved!
i don't know if it has solved that yet. only went for a short test drive last night as i got done around 10 pm. going go karting with dad today, so i shall see then.the gasket was leaking due to no sealant on them and oil eating through it. i used RTV silicone maximum oil resistance sealant with the gaskets on both sides.
