I believe a SRI is a much easier install and to maintain. I'm sure you'll enjoy it!Edit: A few install tips! Disconnect the battery FIRST! Make note of all vac lines on stock system. Make sure when installing all the vac line before the MAF on the stock intake stay before the MAF on the SRI (or even CAI). And same for the vac lines after the MAF.Now on some cars depending on the model and year you may need to add a breather filter to the line runing from the front of the valve cover (1" ID Line). The breather filter is about $10 at an auto parts store. Goodluck!
