Aftermarket System
Sh3pherd
Aftermarket System
Post by Sh3pherd »
Okay, I have a 2006 Vibe, with the 6-Disk CD Changer and the stock 10" sub. Could someone tell me how to install an aftermarket head unit? I know how to in a normal car, but I'm assuming it'd more complicated because of the stock sub. I can get my hands on a Kenwood head unit, a 1000w amp, and 3 10" subs in a box, for pretty cheap. However, I doubt my ability to install that stereo, because this car seems complicated.However, if I do end up doing it, that means I can put that stock woofer and it's enclosure up for sale, which I'm sure a bunch of people would be interested in.I just had a though. Would I be able to use the factory head-unit, bypass the stock amp, and just run it to the new amp which will push the 3 subs?
bigdaddyjosh
Re: Aftermarket System (Sh3pherd)
Post by bigdaddyjosh »
Go to crutchfiield and do the outfit my car option. It'll tell you exactly what you need. You may also want this. http://www.crutchfield.com/p_1...=3486 I believe there is a post here on genvibe about this subject.
Pioneer AVH-P8400BH HU Polk Audio DB-6501 Components Pioneer GM-6400F Amplifier K&N drop-in filter Fiberglass Sub box w/10" Cerwin Vega
Sh3pherd
Re: Aftermarket System (bigdaddyjosh)
Post by Sh3pherd »
So I can hook that thing up to the factory stereo, then connect it to my after-market amp? It's four channel, so then I could use the stock 200w amp to just push the front speakers, and my 1000w amp to push the 3 subs I have?If I got an after-market head unit, would I still need that?
bigdaddyjosh
If you want to connect an aftermarket stereo to the factory amp and just drive your speakers, then you can you use this. Then use the sub-out from your receiver to your 1000w amp.You have to have SOMETHING that will allow you to connect to the factory amp.
CAMOGIRL
Post by CAMOGIRL »
Um, if you'd like to get rid of that stock sub as in the whole panel...maybe we can arrange something lol.
Sh3pherd
Re: (CAMOGIRL)
Post by Sh3pherd »
Well, this will probably be turning into a summer project, because I can't really work too much on my car while it's parked on the side of the street in Philadelphia. However, when I do get around to this, there is a 95% chance of me getting rid of that stock sub, enclosure and all.My plan as of now is to continue to use the stock amp to push the front speakers, which I will probably keep stock. I will be getting another amp and using that to push the subs I get for the back, which will either be 3 ten inch subs, 2 twelve inch subs, or a single (maybe 2) fifteen inch subs. I will also definitely be replacing the stock head unit.So, to wire all of this up, do I still need that stupid thing to get the speakers up to line level? Or can I do it old school, just 2 amps, a head unit, and a wiring harness?
bigdaddyjosh
Re: (Sh3pherd)
does your car have onstar?
Sh3pherd
Re: (bigdaddyjosh)
Post by Sh3pherd »
Nope, no onstar.
joshuaeb09
Post by joshuaeb09 »
I would highly recommend changing out the front speakers. Before I made the swap to infinity's my 3 12's totally drowned out anything. Now with the infinity's I have a good balance. The stock Amp pushes them pretty well actually.
2009 Silver Vibe GT AutomaticI/H/E/Unichip @ 93octaneMy Garage : http://forums.genvibe.com/zerothread?id=43521" onclick="window.open(this.href);return false; - Gone (Sold)
2005 Expedition Limited 2WD|4R75W 4SPD Auto|3.73 Gears|I/E|5Star Tuned@ 91|3" Lift/Level - Current Ride
scherry2
Post by scherry2 »
I hooked up my amp to just drive the sub by using line level converter and wired it into the rear speaker wires
joshuaeb09
Re: Aftermarket System (scherry2)
Quote, originally posted by scherry2 » I hooked up my amp to just drive the sub by using line level converter and wired it into the rear speaker wires Same here except is used the signal for the factory sub and it worked out quite well.
