which M1 filter is the longer one?
21Rouge
Post by 21Rouge »
In the past I have made use of the YZZF1 on my base 05 Vibe. The extra capacity allows me to put a full 4L in the sump.I was going to pickup an M1 filter and wanted one of the same longer size. I had thought it was going to be the M1-103 but this is the smaller OEM size. The M1-102 was in a sealed box and it was longer but at least from the base of the box it appeared to be a larger diameter so I am confused. Which M1 filter is the equivalent of the YZZF1?
10vibe
Re: which M1 filter is the longer one? (21Rouge)
Post by 10vibe »
Just make sure you get the right filter with the right size threads and thread pitch!http://forums.genvibe.com/zerothread?id=43041This forum discussion should get you closer: There might be some outer diameter differences to look out for when trying to get a longer Mobil 1 filter. I hope it does not come down to going to a parts store or Walmart, opening boxes and measuring. http://priuschat.com/forums/ge....htmlThis is a list of Toyota filter # and make and years. Plugging in a couple of these suggests that the Mobil M1103 is the only one really designed for your car, and many other Toyota's.http://www.championtoyotaparts...t.htmhttp://priuschat.com/forums/ge....htmlhttp://priuschat.com/forums/ge....htmlhttp://www.corolland.com/oil-filters.htmlReference charts:http://www.purolatorautofilter....aspxhttp://www.framcatalog.com/Application.aspx?b=Fhttp://www.champlabs.com/ They manufacture many so called high performance brands including K&N, Mobil, Royal Purple, probably some of Bosch, STP, Walmart Super Tech, possibly Penske, Mopar, VW, etc, and some they probably can not tell about.http://showmetheparts.com/champlabs/htt ... yc....html, great site and cross reference and oil discussionshttp://motorcycleinfo.calsci.com/http://www.mobiloil.com/USA-En....aspxh ... ts...t.htm
2010 Vibe 1.8 auto, fwd, base, air, preferred package, cargo mgt, cargo cover, ultra white.
