Help with coolant leak in a 2000 Camry
lovemyraffe
Post by lovemyraffe »
My wife's 2000 Camry, 2.2L 4 cyl, is experiencing a major coolant leak. I've already checked the radiator reservoirs and replaced the thermostat and it is still leaking. Anyone have other suggestions?
808 Vibes
Re: Help with coolant leak in a 2000 Camry (lovemyraffe)
Post by 808 Vibes »
Oh no...pressure test system and cap? Better yet, leave it there and buy another Vibe You could name it "Taxes". You would have "Death" and "Taxes"
~ ALIS VOLAT PROPRIIS ~
keithvibe
Post by keithvibe »
As HPL suggested, have the system pressure checked. They will remove the rad cap put on another cap that alows them to pressurize the system to find the leak.Or you can buy your own and DIYhttp://www.amazon.com/Stant-12...SRGWUThat was just one a a few from a quick google search.Tough to pinpoint, and guessing is just that guessing.Could be something as simple as a lose hose, to something major as a waterpump or head gasket.Are you noticing a low level in just the overflow tank? or in the rad as well?No puddles?
lovemyraffe
Re: Help with coolant leak in a 2000 Camry (keithvibe)
The head gasket is fine. Signs are leading to the water pump. Here's to the water pump!
lovemyraffe
Re: Help with coolant leak in a 2000 Camry (ndrewoods)
I changed the water pump and haven't had a problem since.
