StreetGlow Music Interface and Add-A-Circuit
LarryKingsShoes
Post by LarryKingsShoes »
Greetings!I am considering adding some LED lighting to my 2003 Vibe GT. I've been looking at the StreetGlow Music Interface since it has the option of sound triggered lighting (dancing to the beat) and always-on operation. As tacky as it may be, it seems like it'd be neat to have them flashing with the sub.I'm not very skilled in the area of electronics so I've been doing some research. I've come across a product called Littelfuse Add-A-Circuit. I believe it was mentioned on these boards before.Before I drop any money on equipment, would using something like this: http://www.amazon.com/Littelfu...BGELQ allow me to easily hook up the Music Interface: http://www.amazon.com/Streetgl...r=1-1? From there, would I simply attach these LED strips: http://www.dealextreme.com/p/1...-5256? Also, would this setup (assuming it's a viable option), still require me to ground the Music Interface? Are there any convenient bolts for grounding near the glove box?I plan on having at least four strips (one under each footwell and one under each of the front seats). I may eventually add a couple more but I doubt that I'll ever need to. Would that be too much draw for the circuit?I'd like to thank you in advance for whatever advice you may have. I'll keep doing research but I thought perhaps you guys would have some solid information. I apologize for asking so many amateur questions. I wish I knew more about electronics.Thanks!
Kenwood KIV-700 - Image Dynamics CTX65CS (Front) - Polk Audio db651s (Rear) - Alphasonik PMA640HCA - Kicker ZX750.1 - RE Audio SE Series 12" Subwoofer
