No heat
lovemyraffe
No heat
Post by lovemyraffe »
Weird that it happened after I got the PCM replaced under warranty. I noticed it on my way to work this morning. 1 hour drive @ 80 mph, but never got heat. Any suggestions?
keithvibe
Re: No heat (lovemyraffe)
Post by keithvibe »
this may sound silly.. but did you check the temp dial setting?
lovemyraffe
Re: No heat (keithvibe)
Quote, originally posted by keithvibe »this may sound silly.. but did you check the temp dial setting?ROFL! Yes, I did check the temp dial.
frankiemenz
Post by frankiemenz »
Looks like PCM is behind right side of dash, maybe they left something unplugged related to your heater temperature blend door motor, or along those lines. The figure looks as though the PCM is behind the glove box.
lovemyraffe
Re: No heat (frankiemenz)
Ok, so both Keith and Frank are right. After laughing at myself and Keith for suggesting that I check the temp dial, I got to thinking...what if when they changed the PCM, they knocked the wire off the temperature dial under the dash. So I went and looked at it, and what do you know. I'll double check to make sure the heat is working on my way home tonight. Thanks Keith and Frank for making sure my head is on straight!
keithvibe
Post by keithvibe »
