FWD '09 2.4L Manual told: "don't need to rotate tires on your FWD"
slmclarengt
Post by slmclarengt »
The auto shop my girlfriend went to for her oil change on the vibe told her they did not rotate the tires because it is a FWD. I'm unsure what their reasoning was, whether because of her gender or they saw the tread evenly worn or they believe it is better to replace 2 tires at a time than 4... Is this a normal practice and/or is it correct? Her last LOFR was late last year by the dealer.
ponta2147
Re: FWD '09 2.4L Manual told: "don't need to rotate tires on your FWD" (slmclarengt)
Post by ponta2147 »
I have never heard of this in my life. My husband and I both have FWD cars and we have always gotten tire rotations.
vibe2.1
Re: FWD '09 2.4L Manual told: "don't need to rotate tires on your FWD" (ponta2147)
Post by vibe2.1 »
Per the manual: front to back and back to front (no diagonal and no side to side) every 5,000 miles
ou.grizzly
Post by ou.grizzly »
Time to find a different repair shop that is more reliable with correct information
lovemyraffe
Re: FWD '09 2.4L Manual told: "don't need to rotate tires on your FWD" (ou.grizzly)
Post by lovemyraffe »
Quote, originally posted by ou.grizzly »Time to find a different repair shop that is more reliable with correct informationAgreed. You should always rotate your tires if possible.
slmclarengt
Thanks for the info - I've advised her to 'kindly' demand the repair shop rotate the tires. It must truly be due to gender, because I don't think they could pull the wool over most men's eyes. [Not all women are bad with vehicles, many probably better than me, but you know the stereotype and in this case it held true :]
Re: (slmclarengt)
Quote, originally posted by slmclarengt »The auto shop my girlfriend went to for her oil change on the vibe told her they did not rotate the tires because it is a FWD. I'm unsure what their reasoning was, whether because of her gender or they saw the tread evenly worn or they believe it is better to replace 2 tires at a time than 4... Is this a normal practice and/or is it correct? Her last LOFR was late last year by the dealer.What a bunch of crap ! This is exactly why I rotate my own tires and change my own oil.
