Fender Well, Bumper cover, lower engine cover
Salsa Guy
Post by Salsa Guy »
Yesterday I was a installing grounding/voltage stabilzer kit and noticed the front bumper cover was loose. Upon futher inspection there were about 10 plastic push-in clips/screws missing from the bumper cover, lower engine covers and fender wells. Luckily I had some at the house and replaced them. The only thing I could figure is with all this ice and snow I'd been driving on it had knocked them out. The rear bumper and fender wells looked fine. Left front fender well was rubbing on the wheel and guess it was lucky it didn't get fall off and cause some real issues along with the lower engine covers. I was expecting 2 or 3 to be gone but not that many. I guess with this rough weather it's something we all need to check on. FYI I did need to fix my mini van and mazda with same issues but not nearly as bad.
bassplayaz06
Re: Fender Well, Bumper cover, lower engine cover (rmckinjr)
Post by bassplayaz06 »
i noticed that over the summer when i did the clutch change. it's real brittle plastic so the bumps in the road can make them fall out.
2003 Vibe GT, 1.8L, 6 speed Manual Lava Red 2 tone18" sport edition rimsCosmo CAIMy Garage http://forums.genvibe.com/zerothread?id=42483
Guitarheroal
Post by Guitarheroal »
mine are all gone too. is it important to replace them?
bassplayaz06
Re: (Guitarheroal)
it keeps the panels from flapping around in the wind and vibrating against other stuff. the wheel well shields cant fall out cause they have 3 screws in one spot.
keithvibe
Re: (Guitarheroal)
Post by keithvibe »
Quote, originally posted by Guitarheroal »mine are all gone too. is it important to replace them?Yes, but zip ties would work just fine
Guitarheroal
excellent! i have a ton of zip ties that i can use. thanks for the suggestion!
