DIY splitter
patmanbbe
DIY splitter
Post by patmanbbe »
Anyone ever done this? I have seen many done on other cars. Buy some balsa plywood and cut it out to desired shape. paint and seal to desired color. Cheap and effective!http://www.miataturbo.net/showthread.php?t=41447
epcIII
Re: DIY splitter (patmanbbe)
Post by epcIII »
What exactly is it for? Just curious...
silverbullet
Post by silverbullet »
Aerodynamics. I THINK it kinda breaks up or splits the wind. Reducing resistance. On a vibe tho I'm sure it would only serve for appareances
MotoAce51
Post by MotoAce51 »
Saw a guy at school do this. He used cardboard and body filler to make a mold then made the actual part from carbon fiber.
2004 Vibe Base- Injen CAI, 10,000K HID's, Projector Retrofit W/ Angel Eyes, Billet Grilles, Kicker KX6.5 Components, Helix TB Spacer, Pioneer Premier HU
patmanbbe
Post by patmanbbe »
On any car it makes a huge difference in handling due to increased down force on the front end. It can help you turn in more while cornering and get batter traction at speed while accelerating. It will make a good improvement on the Vibe as many are Front Wheel Drive. In a Front Wheel Drive car you lose grip while accelerating as the weight shifts to the rear and lifts the nose of the car up. A splitter can improve traction by keeping the nose down. If you have a rear or mid wing you should have a splitter to help counter balance the additional downforce at the rear end. Without a splitter when air goes under your engine compartment is gets caught up on all the trans and oil pan down there and doesnt flow smoothly. A splitter smooths out airflow as it goes under your car creating an almost suction or vacuum effect. It is a cheap and effective way to improve the handling of your car. It also looks very cool.
beemerphile1
Post by beemerphile1 »
You made me look. I've never heard of a splitter so I had no choice but to look. I have heard it called an air foil or ground effects.Unless developed in a wind tunnel with extremely deep pockets of cash I would have to say it is nonsense. It could actually cause a reduction in fuel mileage and high speed handling. The factories spend millions of dollars to design aerodynamic shapes. I'll leave that to the engineers.Good news is that it is unlikely to cause any real harm. If not done perfectly it will just look stupid.
03VibeOttawa
Post by 03VibeOttawa »
I would never consider a splitter, or low ground effects on a daily-driver car.I'm curious what an insurance company investigator would say about a DIY splitter if they were trying to minimize their payout after an accident. I can't imagine they'd be okay with it, but maybe I'm wrong.
03VibeOttawa–’03 Salsa 5spd. Fast Wheels Blade 17”s/Fuzion Zr1s (summer),Blizzak Revo1/’04 WRX rims, (winter),Tokico HP Struts,Tein S-Tech Springs,Progress RSB,K&N Typhoon SRI,SLP ram air hood,Magnaflow CB,DC header. Sold 11/9/2012 w/ 217,633kms.
Water boy
Re: (Feelin' The Vibe)
Post by Water boy »
If you want to smooth the flow how about this....?
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
106,019 Yokohama YK580 205/55-16 $589.19 drive out
patmanbbe
Re: (beemerphile1)
Post by patmanbbe »
http://www.miataturbo.net/showthread.php?t=41447Follow the above link and really read it. It is legit and it works. There are alot of people who build their own splitter, One guy makes his own because it is lighter than the one he used to buy. Here is a quote fropm the topic thread:"cjernigan crewed for APR's Rolex team this year at a couple of races, and IIRC he told me that 75% of the cars in the paddock at that event had wood splitters."The professional race team APR Rolex uses homemade plywood splitters! As well as most of the drivers. There was also an episode of top gear where they raced in an event with a BMW 330d. They built and installed a homemade splitter made from plywood. Towards the end of their 24 hour race they had a minor crash and the splitter was ruined. They commented on how much worse the car handled without the splitter. Their lap times were significantly slower after it broke. I did not believe it myself but it is true, cheap and easy to build and it offers significant improvement in handling. There are plenty of how to articles online too. i will try and find a really good one I saw the other day and post it up.
patmanbbe
Post by patmanbbe »
I found it haha! Here is a tech article on how to make your own splitter. Written up by a race team!http://specialprojectsms.com/image/TECHNICAL-2.gif
Kincaid
Post by Kincaid »
I think your research is sound, so if you like the look - go for it!I noted that the plywood they seem to talk about is birch, not balsa.It might be a little out of place on a Vibe, and I'm not sure you'll ever be going fast enough to really make a difference - but so what?I'd perhaps do the same thing myself if I thought it would improve my mpg. I plan on making a front lip using garage door seal, so I certainly understand you wanting to go forward with a mod like this.Just make it sturdy!
MotoAce51
Post by MotoAce51 »
Hey why not. Look at the Morgen (sp?) it has a lot of wood in it. Paint it and you may never know its actually wood...
