TPMS reset ... NOT
Water boy
TPMS reset ... NOT
Post by Water boy »
Am I the only one who can't reset the TPMS idiot light on my '08?I've followed the owners manual.I get the 3 blinks.I know the tire PSI is correct at 32 on all 4.What am I missing?
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
106,019 Yokohama YK580 205/55-16 $589.19 drive out
Cruxless
Re: TPMS reset ... NOT (Water boy)
Post by Cruxless »
Have you checked your spare tire? Some spares are equipped with tpms sensors and they can cause the tpms warning light if not properly inflated.
BurnOnyx08
Post by BurnOnyx08 »
Had to do this many times in my '08, with the aluminum rims I tend to lose a lot of air. Inflate to preferred pressure. Begin driving. Hold button for a good 5 seconds and it should calibrate in the next few miles. I'm positive there is no TPMS in the spare as I had it on all 4 corners due to the OEM tires being crap. This is not the way the manual says to do it, but it works for me.
ehoff121
Post by ehoff121 »
Quote, originally posted by Water boy »I know the tire PSI is correct at 32 on all 4.Please double check your pressure- my '05 has 35 PSI on the fronts and 32 PSI on the rears.You also need to drive over a certain speed for an hour or two as in the manual.Apparently, the '08 has TPMS sensors in the tire valve unlike the previous generations. Could it be a malfunctioning sensor?
lovemyraffe
Post by lovemyraffe »
Quote, originally posted by Water boy »What am I missing?Follow the directions in the manual. It takes more than just pushing the button on the dash. I think it wants you to drive for an hour or so, like others have said.
Water boy
Post by Water boy »
So, what is the sequence you believe works?PSI checkedResetDriveDid that.No fixy.
2008
70,395 Battery
Water boy
Re: TPMS reset ... NOT (lovemyraffe)
Post by Water boy »
Any way to discover if there is a bad sensor?
2008
70,395 Battery
