Best way to fix this...
bax08
Post by bax08 »
My vibe has a little over 97,000 miles on it and the interior is holding up very nicely, except for what you see in the pics. Before I go slapping some super glue on this, I as wondering if there might be a better way to fix this?
Wolfman213
Post by Wolfman213 »
Finish popping it out and see if the clip is still there. If I remember right, it's kind of finicky on getting put back into place.
ou.grizzly
Re: Best way to fix this... (bax08)
Post by ou.grizzly »
I think that part has broke on everyone's Vibe.
lovemyraffe
Re: Best way to fix this... (ou.grizzly)
Post by lovemyraffe »
Quote, originally posted by ou.grizzly »I think that part has broke on everyone's Vibe. Mine are broken on both the drivers and passenger side.
Wolfman213
I must be lucky then bc I've popped mine out SEVERAL times and still not broke *knock on wood*
epcIII
Post by epcIII »
Mine was broken too and it really bothered me. So I put the tiniest of screws through it and into some plastic underneath. If I painted the screw solver you would hardly notice it. Reason I didn't glue it was sometimes you need to take that off if you need to fix something in the door.
bassplayaz06
Post by bassplayaz06 »
i actually just fixed this on wednesday. all the clips on the right side of it and the one on the back were gone. i got some plastic epoxy and glued some peices of plastic similar to the original clips where they went. let it sit for a day and it was perfect.
2003 Vibe GT, 1.8L, 6 speed Manual Lava Red 2 tone18" sport edition rimsCosmo CAIMy Garage http://forums.genvibe.com/zerothread?id=42483
DiveNut
Post by DiveNut »
Mine broke too...I cut a few strips of velcro to hold it in place. Not fancy, but wht.
Bare Bones Base, Abyss 2004 Vibe, Debadged, Auto, ABS, GM Performance Supercharger, Injen CAI, 2.3" URD Pulley, Unichip,Tru-Cool Tranny Cooler SOLD
1972 Plymouth Duster 340 (Strip/Street Project)
mac99d
Re: Best way to fix this... (DiveNut)
Post by mac99d »
+1 for broke
Mac's Vibe.
DJ_Losch_411
Post by DJ_Losch_411 »
Dang, I guess i got a lucky vibe lol, 130,000 on my GT and interior is still strong... *knock on wood also*
*2005 Stock Vibe GT* *Kawi Racer* See My Garage http://forums.genvibe.com/zerothread?id=43702
bax08
Post by bax08 »
Sounds like the best solution is to use velcro or just let it be. Thanks for the replies!
DeClerq
Post by DeClerq »
The front clip on mine broke so every time I tried to raise the window the whole assemble would pull out. The plastic piece that hangs down was still there (I think I there was a metal clip that attached that piece of plastic and it went missing). I took the door panel off and then put a small screw through that plastic piece. The screw is just big enough to keep the panel from raising up any. No problems with it since.
'09 Mazda5 Grand Touring'04 Vibe - M&T, Power Package, Protection Package
scherry2
Re: Best way to fix this... (DeClerq)
Post by scherry2 »
Quote, originally posted by DeClerq »The front clip on mine broke so every time I tried to raise the window the whole assemble would pull out. The plastic piece that hangs down was still there (I think I there was a metal clip that attached that piece of plastic and it went missing). did you check in the door for the clip? cause if the clip came off it fell in the door not out.
keithvibe
Post by keithvibe »
No issue with mine yet... had it out three times now
kostby
Post by kostby »
I ordered a new one from the dealer a couple of years ago. I think it was around $30, but they installed it for free because it was the same time as the window recall, so they had to take the door apart anyway.
DeClerq
Re: Best way to fix this... (scherry2)
Post by DeClerq »
Quote, originally posted by scherry2 »did you check in the door for the clip? cause if the clip came off it fell in the door not out.I looked, couldn't find it anywhere. Hence my screw solution.
Guitarheroal
Post by Guitarheroal »
the back side clip of mine is completely broken off. i bought some loctite general purpose automotive adhesive. you guys recommend using it? I dont think i will be needing to fix anything in the door
Guitarheroal
bump! i'll probably just try using it tomorrow anyway if no one responds
Ls1jorge
Re: (Guitarheroal)
Post by Ls1jorge »
+10 yup mines broke 3weeks ago driverside door,
05 Vibe-Pioneer indash touch, Remote Start Alarm, TSW 18 inch.
99 Camaro z28- Cammed/Stalled/Full Bolt Ons
bassplayaz06
Re: (Guitarheroal)
if you have some epoxy, do what i did. easiest if you even wanna think about taking it back out.
Guitarheroal
i wish i could, but the clip on the panel broke off as well as where the clip goes into. I have no idea where they went either. i might be sol and will try to just glue it on.
MotoAce51
Post by MotoAce51 »
Mine was getting loose and I was getting annoyed and I tried to take it off and it officially broke. Its too darn cold out right now to do anything with it so I tried the velcro idea. Works well. Its not perfect but I am happy for now. I will prob get a new one in the summer but the velcro works really well. You just need to get some good stuff not cheap.
2004 Vibe Base- Injen CAI, 10,000K HID's, Projector Retrofit W/ Angel Eyes, Billet Grilles, Kicker KX6.5 Components, Helix TB Spacer, Pioneer Premier HU
Guitarheroal
Re: (bassplayaz06)
Quote, originally posted by bassplayaz06 »if you have some epoxy, do what i did. easiest if you even wanna think about taking it back out.oo nvm, found the broken piece. going to try to epoxy it back on, but it looks like an extremely cheap piece. hope it holds!
jesshaun
Post by jesshaun »
Anyone know where to find a replacement piece before I just buy some velcro for it?
IMakeVibes
Re: (jesshaun)
Post by IMakeVibes »
Quote, originally posted by jesshaun »Anyone know where to find a replacement piece before I just buy some velcro for it?Junkyard or dealer? And yes, mine was broke when I got the Vibe and its more broke now...
bassplayaz06
Re: (Guitarheroal)
well, mine was fine til the dealership decided to break it again.... i used some weak epoxy so it busted off. i'll get some velcro or something on there tomorrow.
MotoAce51
Post by MotoAce51 »
The velcro is only a temp fix. Mine is coming loose again. But its warming up now and I will get a replacement part. Its annoying when it shifts off to the side.
bax08
Post by bax08 »
Does anybody know the part # for this piece? Do the vibe and matrix use the same part? The reason I ask is b/c it appears the matrix part is much cheaper than the vibe part, $14.16 vs. $57.02.
