Heater core replacement
jtnovibe
Post by jtnovibe »
I'm going to tackle replacing the heater core on my friend's 2003 Vibe GT probably on Monday. I couldn't find any relevant posts here, so I'm wondering if anyone has any tips or advice.Thanks!-JT
Re: Heater core replacement (jtnovibe)
Good luck..... You'll most likely be removing a large chunk of the dash. It's messy, cramped and your knuckles will bleed at some point... Oh, make sure that you put the hoses back the right way on the new heatercore or it can trap air!!!Take lots of pics though!!!
jtnovibe
Re: Heater core replacement (star_deceiver)
Post by jtnovibe »
Well after about 8 hours of disassembling everything from the firewall back, I could barely glimpse the side of the heater core. As far as I can tell, the A/C evaporator has to be removed to get to it. Even if I wanted to do that, which I don't, I couldn't even see a way to disconnect it.Until this, I always thought I could do anything. This has to be the worse car to work on that I've ever seen. I'm going to tell my friend that if she wants heat she should set the car on fire.-JT
jtnovibe
Post by jtnovibe »
Yes, the A/C evaporator has to be removed. She found a friend of a friend to do it for $300 labor. He didn't refill the freon, so that's probably another $100, and fixing some of the problems he caused took me a couple of days. I still think she should have set the car on fire. By the way, there's a Spectrum Premium core for something like $57 that DOES NOT FIT! Get the OEM part if you're stupid enough to try this on your own.-JT
jake75
Post by jake75 »
Reading these kinds of posts makes me think I did the right thing by selling my 2003 2 years ago and jumping on a bargain basement priced 2009.
