This is Phase ONE of my attempt to convert all my rear lights in my car to LED without my S.O. knowing. Ok, so I finally got around to getting LED license plate lights, and got them in the mail today. I have pics, but they are a little blurry(sorry I have a crappy camera that does not like low light situations)Ok so, onto my how to.My how to is basically how to purchase and install LED lights WITHOUT your wife or significant other knowing. See, my wife hates when I modify or change something on my car, and when I say hate, I mean she DESPISES it to no end.So, here are a few steps in securing some new lights without her knowing. Now first off, I will state a small disclaimer. What I am about to type should in no way mean that 1) you should attempt this 2) are going to get away with it if you do 3) will not get in trouble if you get caughtSo proceed at your own riskOk before you attempt this, there are a few things that you MUST either have control of, or can hide.#1 - You must have control of the finances - meaning that you can either hide the transaction as buying a pack of smokes, or in my case going out for lunch with co-workers (I love bank of america and the ability to rename transactions)#2 - You must be the one who checks the mail or have a seperate PO BOX - failure to do so can result in said S.O. obtaining package and then ripping your package from you(if you get my drift)If you do not control or posses the ability to control either of the two above, DO NOT ATTEMPT!!!Ok, now for the stepsStep 1Go on-line to your favorite LED shop. Mine happens to be
http://www.frickinbrite.com/catalog/Step 2Pick out your favorite set of lights. Mine were
http://frickinbrite.com/catalo...W.jpgStep 3Purchase said lights and then proceed to watch the bank account for the posting and update the transaction with whatever cover story you so chose.Step 4Check your mail DAILY!!!! Keep on it or else it can be hazerdous to your health. In my case I always get home before my wife so, there is no excuse.Step 5Once package is received, open it to make sure everything is there. Here are a couple of shots (for size comparison) of what the new lights look like.Old light with new lightI will say that they fit perfectly, no problem what so ever. Step 6Begin by removing the cover on your hatch. This can be accomplished with a flat head screwdriver and a paper towel (to aide in not scratching the plastic)Step 7Remove the bulb holder from the assembly by rotating it counter clockerwise (for you time challenged people who have never owned an analog watch, that means to the LEFT!!!)Step 7.2 (optional)You can either disconnect the entire bulb holder (as you see I did above) or leave it connected. I will say that it is easier to remove the old bulb if you disconnect the holder as you are not having to reach over your head for it.Step 8Remove old bulb and replace with new LED bulb. Reconnect holder(if you removed) and then turn lights on to test. These lights only work in one polarity so I had to remove the lights and flip them around to work.It should look something like this - both bulbs dangling from harnessNow repeat steps 7 through 8 for the other bulb. Step 9Reinsert the bulb holder into the socket(it will only go int one way so do not force it in). Once inserted, rotate the holder clockwise (if you have not already figured out the difference between clockwise and counter-clockwise, you need to seriously consider giving up on ever having a life or career for that matter) Do this for BOTH bulbs.Step 10Once both bulbs are back in and secure, place the plastic cover back onto the rear hatch (note - each side of the cover has different size tabs. The smaller tabs go toward the glass side of the hole, while the longer tabs are toward the latch side)Step 11Make sure that the lights are working before you call it a day (double checking now can avoid the smokies later)If both lights are on, then you are in great shape. Your final thing to do is to get rid of ALL evidence that this has occurred. This means, trash the envelope, the old bulbs, and shred the receipt (this company keeps track of your purchases on their website and you can request a new receipt if need be as it was issued through Paypal)Now all you have to do is sit back, and make a post this long while your S.O. is in the kitchen directly behind you without a clue as to what has occurred or what you are typing up currently. (damn I am ballsy hehehe) Phase ONE complete - onto Phase TWO (might take longer cause it was easy to hide $13, not so easy to hide $30+)
