Quote, originally posted by rmckinjr »OK here's what I know. It's a Pioneer GM-7200M (
http://www.crutchfield.com/S-wUJ1T9ZOeD ... 7200M.html) Specs are 250 Watts RMS @ 4 ohms, 360 watts RMS @ 2 ohms. The gain is set to Normal (preout level: 2V), LPF is set to aprox 100 hz, Bass Boost Control is set to 12 dB. There's a BFC but I've never messed with it. I don't know the exact box dimensions (home made) I want to say the side top is 5" to 8" on bottom, 18" high and 24" wide. It's not ported and fits behind the seat (standard cab truck). From what I'm reading the settings my need to be adjusted but how to you set it up? I guess it's like tuning a car and hitting the sweet spot!Well Sir, just to start, here is a perfect example of the smoke that audio manufactures blow at youThat amp has on it 800w.... it carries 2x 30a fuses... Ohms law states that W=EI... (E =voltage, I =amprage) so 12x60=720w That is the ULTIMATE MAX, at the point where the fuses blow... You'll NEVER reach that point unless something is wrong.. If you look at the specs on the Crutchfeild page, it says PEAK output of 500w @4ohm, and doesn't GIVE a PEAK for 2ohm... It says it will do 250wrms @4ohm and 360wrms @2ohm... Now settings... 1) The head unit.. is it a knob or button volume? does it have a number for volume level?? If so, what is the MAX that this is used at? 2) The amp, is the "gain" setting a knob or a switch? if it's a knob, how far from ZERO would you say it is? 3) we'll get to bass boost in a few... but "BFC" is Bass Frequency Control and that should allow you to pick a frequency to boost.. 4) again on the sub box... It MAKES the sub... you can take the best sub in the world and put it in a miss-matched box and it will sound like garbage and can have terrible power handling... Inversely, you can put a "soundstorm" in a properly designed (sized really, it more about internal volume) and have it sound AMAZING... If you can/would, do you have a cardboard box lying around that would be ~12"x12"x12" (1 cubic foot) and some packing peanuts? You can remove the sub, fill the box with packing peanuts and fill the sub box.. each box you dump is 1cf.. it's a SUPER easy way of finding volume... You can also measure the outside of the box, subtract stock thickness, get cubic inches and do the math.. 1 Cubic Foot = 1728 Cubic Inches The problem with something like SoundStorm (which is a rip from SoundStream, one of the greatest audio companies) is that they offer very little in terms of speaker specs.. I mean, if they have a "recommended" enclosure size noted somewhere, it's useful.. NOW: level setting... Proper level setting is both scientific and subjective.. I like to direct people to download 2 different test tones... http://homerecording.about.com...s.htmYou want 60hz 1000hzBurn the tones to a disc (or have the son do it, whichever)Now, in the car, play the tones on repeat.. (unplug the RCA's from the amp first)Start with the 1000hz tone.. play the tone and turn the HU up untill you hear a DISTINCT change in output... turn it down and try again... Once you find this point where the tone changes back off a notch and NOTE that point... That is now your HU MAX.. This is the point in which the HU begins to distort.. NOTE: if you have mids/tweeters amped, there is more to this, I don't think they are amped, so this is good for now)Now that you have your HU max, move to the amp... FIRST OFF turn the bass boost to zero, gain to zero everything to zero.. (plug the RCA cables back in)Now, play the 60hz tone (bass and also what comes out of a wall socket) at the head unit MAX you just found... Now, move to the amp, turn the GAIN up, until you hear a distinct change in sound, back off, try again... FIND THAT SWEET SPOT.. Find the spot and back off slightly.. This should be your amps MAX gain before distortion... Ok from here, you need to play some music and see how things sound... This is a general set-up guideline, BUT, music is dynamic, it's not a single tone... The single tone just allows you to identify distortion easier, because it's not masked in music.. BASS BOOST... Let's talk... Sound is interesting, power to output is an inverse relationship.. The human ear can only notice increases in volume in 3db increments.. To increase output of a speaker system by 3db roughly requires DOUBLE the power.. This is why most speakers are rated at 1w at 1 meter.. and usually produce 85-95db on 1 WATT... But at 50w they same speaker may only produce 110db... at 100w.. 113db... SO, with the bass booost set too 12db... you are asking that amp to QUADRUPLE it's power into whatever frequencies the BFC is set to.. This is NOT good on an amp that doesn't have much for output to begin with... Used sparingly.. Whew.. chew on that for a few.. get back to me... BTW, we DO have an audio section.. I do my best work there..
