O2 Sensore replacement
Salsa Guy
Post by Salsa Guy »
How do reomve and install an O2 on the exhaust Manifold. It surround by a Heat shield Donut and there's no way to get a wrench on it. HELP!
epcIII
Re: O2 Sensore replacement (rmckinjr)
Post by epcIII »
I might be crazy, but I think I remember a post about reaching an O2 sensor underneath the carpet.Anyone?Edit: Try these thread: http://forums.genvibe.com/zerothread?id=41173
Salsa Guy
Re: O2 Sensore replacement (epcIII)
Post by Salsa Guy »
Quote, originally posted by epcIII »I might be crazy, but I think I remember a post about reaching an O2 sensor underneath the carpet.Anyone?Edit: Try these threads: http://forums.genvibe.com/zerothread?id=41173 and this one with pics: http://forums.genvibe.com/zerothread?id=22020 Those are for the one at the CAT. This one is on the Manifold and has a heat shield around it.
epcIII
Post by epcIII »
Oops...
BlueCrush
Post by BlueCrush »
Quote, originally posted by rmckinjr »How do reomve and install an O2 on the exhaust Manifold. It surround by a Heat shield Donut and there's no way to get a wrench on it. HELP!IMed you back on this issue.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
BlueCrush
Re: O2 Sensore replacement (BlueCrush)
Post by BlueCrush »
My Fleet:
epcIII
Post by epcIII »
Is this the one where you have to make sure it's hot so you don't ruin the threads?
Salsa Guy
Re: O2 Sensor replacement (epcIII)
Post by Salsa Guy »
Quote, originally posted by epcIII »Is this the one where you have to make sure it's hot so you don't ruin the threads?Really? I know heating nuts makes them easier to come off so I suppose that makes sense. Thanks!
Salsa Guy
Post by Salsa Guy »
Quote, originally posted by BlueCrush »Mine looks like this: http://www.amazon.com/TEKTON-4...PUKIEWill check at Auto Parts store for a loaner. Or maybe buy one. Yea had P0133 and from everything I've read it's a bad O2. Suppose I should check the TRD wiring also. Thanks!
epcIII
Re: O2 Sensor replacement (rmckinjr)
Post by epcIII »
I saw that on this thread: http://forums.genvibe.com/zerothread?id=39708 Do'h!
keithvibe
Post by keithvibe »
it doesn't need to be hot. Warm yes. Piping hot no.I've removed mine several times while cold with out issue.Unplug it and use the O2 socket that BC linked for it to be removed.I have one just like this one
Salsa Guy
Post by Salsa Guy »
Thanks Guys!
