i also think that there was some more restrictive exhaust routing to get around the AWD pieces. The engine is the same but doesn't flow as well due to that and has a few HP less. People who truly need AWD definitely don't need more power since you are barely on the gas in low traction situations.
07 1ZZ 5spd Stealth - Sold
03 1ZZ 6spd Shadow w/NAV - For Sale
06 AWD Stealth - Current
07 Magnum SRT-8 - Current
Quote, originally posted by keithvibe »they didn't intentionallyIt's the same engine that the base model has.. It just has the least because they added awd to it.Yup, drivetrain losses drain the HP out of the AWD.Quote, originally posted by Bedlam »i also think that there was some more restrictive exhaust routing to get around the AWD pieces. The engine is the same but doesn't flow as well due to that and has a few HP less.And this! ^Quote, originally posted by Bedlam »People who truly need AWD definitely don't need more power since you are barely on the gas in low traction situations.Ummmmm....riiiiight!Quote, originally posted by bassplayaz06 »ah, that makes sense. HP is one of the reasons we bought the 03 GT considering it has the most stock power.Sounds like you made the right choice, then.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Quote, originally posted by BlueCrush »Ummmmm....riiiiight!notice i said "truly need" and not "like to have"yea, it is fun jetting around town but no vehicle that needs to get up nasty snow filled hills or down icy roads has any need for more than a 100hp. Yes we want it the other 99% of the time but definitely don't need it.I wanted a 450hp RWD wagon so i bought one. I don't need more than my bone stock base FWD vibe to go anywhere.
The 1.8 AWD almost can't get out of the way of itself. There's nothing like trying to complete a pass with a Semi bearing down then you stomp the gas and the car laughs at you. It needs just a tweak say maybe 30 more HP.
You are correct! However the SC does help a bit! Keith will be adding a TC soon maybe he'll get his 80-100 + hp. If he doesn't shell the tranny, transfer, diif.....LOLWhat's the HP rating on the 09 AWD?
Quote, originally posted by rmckinjr »You are correct! However the SC does help a bit! Keith will be adding a TC soon maybe he'll get his 80-100 + hp. If he doesn't shell the tranny, transfer, diif.....LOLWhat's the HP rating on the 09 AWD?Tuning will be the interesting part for Keith and you are right, hope that weak arsed trans, transfee case, and rear diff does not give out. Thing is like glass. 158 or something
Quote, originally posted by ou.grizzly »Tuning will be the interesting part for Keith and you are right, hope that weak arsed trans, transfee case, and rear diff does not give out. Thing is like glass. 158 or somethingYea I heard that about the AWD and that's why I'll be upgrading all the fluids soon. Also have a rear diff leak that will need to be addressed soon (the level is still good). T&A can tune with the best of them from what I read, I'm sure he'll be in good hands. hmm 158??? I'll make a run at ya. coming to OK soon...LOL. Have no idea what mine is doing. Need to get the TuRD ECU out and get it tuned with the EMU.
Quote, originally posted by rmckinjr »Yea I heard that about the AWD and that's why I'll be upgrading all the fluids soon. Also have a rear diff leak that will need to be addressed soon (the level is still good). T&A can tune with the best of them from what I read, I'm sure he'll be in good hands. hmm 158??? I'll make a run at ya. coming to OK soon...LOL. Have no idea what mine is doing. Need to get the TuRD ECU out and get it tuned with the EMU.Some folks over at MO who had a TRD on their AWD were running lean/
Quote, originally posted by ou.grizzly »Some folks over at MO who had a TRD on their AWD were running lean/They were using a SRI/CAI and maybe didn't have the 5th injector hooked up. For the most part is runs rich based upon how it runs right now. I don't have my A/F hooked up yet (my SRI is also on the shelf) that's a project after the holidays and get the exhaust done, Diff leak fixed, fluid change over and etc. I'm quite happy with it now, fuel mileage dropped some. Hope to get my wife in another car soon!
