Quote, originally posted by rmlmt »Trying out some Amsoil P.i. Fuel injector cleaner. I've heard good things about it. I'll keep you updated to see if I notice better fuel economy after I use it. Got it for 10 bucks at ACE Hardware.
http://www.amsoil.com/storefront/api.aspxrmlmt: You certainly chose the right one! AMSOIL PI is not just a fuel injector cleaner, rather a fuel SYSTEM cleaner. It cleans every thing it comes in contact with. Fuel Pump, Pump Screen, Fuel line, Intake Manifold, Injectors etc., plus lubricates rings & upper cylinder walls. When used regularly, you'll get better MPG, also a little more HP & Torque. May I also recomend AMSOIL Octane Boost. I run both in my Vibe. On a trip this past Oct., of just over 600 miles, my Vibe got 42 mpg on the HWY.
David A. BessLifetime/T-1 Certified AMSOIL Dealer #308982
