timing chain question
69rustang
Post by 69rustang »
I am in the process of changing out the crank in '03 Vibe GT. Spun #2 rod bearing. I tried to get the timing marks to align, but they don't align when crank damper is at 0 degrees. The exhaust cam is off a few degrees when crank and intake cam are where they should be. the colored chain links are where they are supposed to be. Any ideas?
keithvibe
Re: timing chain question (69rustang)
Post by keithvibe »
You would be better off asking over at newcelica.org... more experienced engine builders there
ou.grizzly
Re: timing chain question (keithvibe)
Post by ou.grizzly »
Quote, originally posted by keithvibe »You would be better off asking over at newcelica.org... more experienced engine builders thereJoatmon may be able to answer this question, hope he comes across it.
