OOPS! Isterring 12v constant not working!
Laserbeak43
Post by Laserbeak43 »
hi, ive checked the fuses and ran a meter on the wire but im noy getting voltage from the thick black wire in the ignition harness.all of the electricity seems to be working otherwise. The domelight headlights radio and dash all turn on and when the key is inserted the dash does its thing. but i get nothing when i try to crank the engine.Can someone please help?
Re: OOPS! Isterring 12v constant not working! (Laserbeak43)
double check the 30A "MAIN" fuse in the underhood fuse block and the 15A "AM2" fuse n the under dash fuse blockdoes your 2006 Vibe have a manual or automatic transmission?What did you do to the car between when it last worked and when it first stopped working?
Laserbeak43
Re: OOPS! Isterring 12v constant not working! (joatmon)
I have a manual and i was playing around with the relays i've connected to the 12v constant.nothing is busted under the hood and i don't see a box in the car. even looked in the manual to see if it'd tell me where it is but i don't see it.
keithvibe
Post by keithvibe »
the second fuse box is under the steering wheel on the driver side. Lay on the floorboard and look up.
Laserbeak43
ok i see that, but i have no idea how i'm supposed ot get to that!!do i have to take the dashboard off?
keithvibe
Re: (Laserbeak43)
Post by keithvibe »
nope, lay on your back and reach up.
Laserbeak43
it's too the far left last i looked it didn't look like i'd be able to reach the fuses(there are only 3 there, am i looking at the right spot?) i'll try and check them.
Laserbeak43
Re: (Laserbeak43)
OK the 15A was blown, the car starts now. I have no 30A main on the inside of the car, and the one outside seems to be fine. I did blow my alarm brain in the process. Luckily it was the alarm brain company's tech support that advised me to do what led to the busted brain. that should allow me to get it replaced.thanks again for the help.
Sublimewind
Re: (Laserbeak43)
Post by Sublimewind »
Quote, originally posted by Laserbeak43 »OK the 15A was blown, the car starts now. I have no 30A main on the inside of the car, and the one outside seems to be fine. I did blow my alarm brain in the process. Luckily it was the alarm brain company's tech support that advised me to do what led to the busted brain. that should allow me to get it replaced.thanks again for the help.You "sure" it's a good idea for you to b playing with the electrical of your car...? You don't sound the most competent with common car systems.. I mean 95% of cars I know has the fuse panel under the drivers dash.. I don't mean to sound rude, but I also don't candy coat things that could be a hazard to yourself or others... Not sure if you've ever seen a car go up in flames due to crappy wiring, but I have.. I used to fix all of it for a living... I could tell you WHICH shop it came from, or weather it was a driveway job gone bad.. Nothing personal I assure you.. I'm just to the point..
I learned about the underhood fuse block here at genvibe. The inconvenient location of that fuse block has been a source of woe for many of us. The 12V outlet in my dash is touchy, I've blown a few CIG fuses. The 2006 owners manual does describe the under dash fuse block on page 5-92, but only gives a token description of it's location. For anyone wanting a copy of any year's Vibe Owner's manual, you can download them from links in http://forums.genvibe.com/zerothread?id ... limewind's signature has a link to an on-line version of the 03 Toyota Matrix service manual. Almost all of that still applies to 2006 Vibe's as well. I've used those wiring diagrams a lot.I would probably use a different source for the constant 12V for the alarm instead of the line running to the ignition switch. Perhaps use one of those "add-a-circuit" things to add a separate fused line right at the fuse block, or tap into the constant 12V feeding the radio, or several other sources. I try to not mess with the main ignition line, because if something goes wrong, well, then the car won't start
Laserbeak43
Re: (Sublimewind)
Quote, originally posted by Sublimewind »You "sure" it's a good idea for you to b playing with the electrical of your car...? You don't sound the most competent with common car systems.. I mean 95% of cars I know has the fuse panel under the drivers dash.. I most certainly am learning, and I did see that the manual said it was there but i've never seen it "UNDER", under the dash before, but by the kickpanel in a million and one cars. and i've stared at it for hours but didn't notice it, because it's the smallest fusebox i've ever seen. I just thought that it was something else.Quote »I don't mean to sound rude, but I also don't candy coat things that could be a hazard to yourself or others... Not sure if you've ever seen a car go up in flames due to crappy wiring, but I have.. I used to fix all of it for a living... I could tell you WHICH shop it came from, or weather it was a driveway job gone bad.. Nothing personal I assure you.. I'm just to the point.. I can imagine the drama that I could cause, and I make sure that I study everything and test leads and install the proper equipment to prevent fires and shorts and things like that. Not saying that this is any excuse for me to not know better, but it was actually the alarm company that instructed me to reverse the two wires that caused the short. I figured it was a blown fuse protecting the rest of the car, but I couldn't find the box under the car.And I appreciated the blunt advice, even if i might've been a little upset if you didn't put the suguar coated disclaimer in it
Laserbeak43
Quote, originally posted by joatmon »I would probably use a different source for the constant 12V for the alarm instead of the line running to the ignition switch. Perhaps use one of those "add-a-circuit" things to add a separate fused line right at the fuse block, or tap into the constant 12V feeding the radio, or several other sources. I try to not mess with the main ignition line, because if something goes wrong, well, then the car won't start sorry, when i replied last i was working on finals for school. Where are some other 12v constants? Only reason I chose the ignition was cause i couldn't find another. I'm not very comfortable with the ignition being tapped either, tbh.
Laserbeak43
Bumskigedy bumskigedy bump!
