Audio "Hot Deals"...
Sublimewind
Post by Sublimewind »
Hey everyone... On most of my other forums, i've convinced the mods to allow us to run a "Hot Deals" thread in the audio section.. I've tried getting a general hot deals thing going here in the past, but not with blessing.. So here I am, with another grip of "hot deals" and have a hard time sharing them with all of you.. So maybe we can appeal to the mods, get something started.. My first "Hot Deal" will be these Blaupunkt VX652 coaxial... http://www.ikesound.com/produc...VX65242.00$3" voice coilsCarbon Fiber coneFlush tweeterMounting depth claimed at 1.65"I bought a set for the Vibe..
Sublimewind
VIBE Audio LiteBox Stereo 4 (LiteBox4) (ARC Audio Mini clone) 200$..... http://www.sonicelectronix.com....html.# SuperCar Series 4-Channel Class GH Car Amplifier# RMS Power Rating: * 4 ohms: 90 watts x 4 chan. * 2 ohms: 125 watts x 4 chan. * Bridged, 4 ohms: 250 watts x 2 chan.# Max power output: 1000 watts# MOSFET Power supply# Remote level bass control included# LED power protection indicators# Bass Boost EQ (0-15 dB bass boost at 45 Hz)# Auto Sense circuit allows the amplifier to turn on/off without a remote turn-on wire# 4/3/2 channel operation# Microprocessor monitors and protects the amplifier# Internal Convection Cooling (ICC) allows for a heatsink design since the cooling fans are mounted insideLearn more about theVibe LiteBox Car Amplifiers# Heavy duty aluminum alloy heatsink# High and low-levels inputs# Full, high and low-pass crossover# Silver-plated RCA level inputs# Silver-plated screw terminals# High-pass filter (55-550 Hz)# Low-pass filter (55-550 Hz)# Frequency response: 20-20,000 Hz# Dimensions: 5-1/4"D x 11-3/4"W x 2"H# 4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Sublimewind
VIBE Audio LiteBox Bass 1 (ARC Audio Mini clone) 200$http://www.sonicelectronix.com....html# SuperCar Series 1-Channel Monoblock Class GH Car Amplifier# RMS Power Rating: * 4 ohms: 300 watts x 1 chan. * 2 ohms: 500 watts x 1 chan. * Strapped, 8 ohms: 600 watts x 1 chan. * Strapped, 4 ohms: 1000 watts x 1 chan.# MOSFET Power supply# Remote level bass control included# LED power protection indicators# Bass Boost EQ (0-15 dB bass boost at a variable 30-125 Hz)# Auto Sense circuit allows the amplifier to turn on/off without a remote turn-on wire# 1 channel operation# Microprocessor monitors and protects the amplifier# Internal Convection Cooling (ICC) allows for a heatsink design since the cooling fans are mounted inside# Heavy duty aluminum alloy heatsink# High and low-levels inputs# On-board Linkwitz-Riley active low-pass crossover# Silver-plated RCA level inputs# Silver-plated screw terminals# Input sensitivity: * Low level: 0.75V-6.6V * High level: 6.7V-13V# Frequency response: 20-230 Hz# Phase Switch (0-180°)# Dimensions: 5-1/4"D x 11-5/8"W x 2"H# 4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Sublimewind
The speakers from the first post.. Carbon Fiber cone, 3" Voice Coil, pole mounted tweeter (flush, or lower than the speaker surround)Cast basket, rubber magnet cover, sealing gasket.. cover removed...Top mount depth 2.65"
Sublimewind
same as above 6.75" version... 33.00$http://www.ikesound.com/product-product_id/5788
cptnsolo77
Post by cptnsolo77 »
Kool! How do they sound?
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
Sublimewind
no idea yet, got them today..
cptnsolo77
Re: (Sublimewind)
Keep us posted! Im looking to replace the rears but not ready to shell out $100 + for a Polk component system. Looking for a second choice. The specs & construction is impressive for the price though.Im all for a "hot deals" section. Everyone wants to get more value for thier money!
