New Member from Michigan
2005VIBELO
Post by 2005VIBELO »
Thought i would stop in to say hello. My wife and I own a 2005 Vibe (2wd) base model. No mods to it, but i do expect to put some E3 Plugs in it when i replace the 02 sensor. The check engine light is on currently and I took it to Autozone and they said its probably the first O2 sensor that is bad... Any thoughts? I also have some other questions about a defrosting problem so I'll post those elsewhere. Thanks for the great site!
bull77
Post by bull77 »
Welcome to Genvibe!
Re: New Member from Michigan (2005VIBELO)
Welcome to GenVibe!!!
areles
Post by areles »
Welcome to the forums!
Zimm
Post by Zimm »
welcome fellow michigander and OC'er!
wt2ga
Post by wt2ga »
WELCOME
808 Vibes
Re: New Member from Michigan (wt2ga)
Post by 808 Vibes »
Welcome
~ ALIS VOLAT PROPRIIS ~
jkm311
Post by jkm311 »
Welcome. Maybe see you around!
Steelies to the rescue.
midnighthunder89
Post by midnighthunder89 »
welcome. if you know the codes for the check engine light there is usually someone on here that can tell you what they mean.
2010 Vibe 2.4L 5 speed manual.
lovemyraffe
Re: (midnighthunder89)
Post by lovemyraffe »
Welcome to GenVibe!
kostby
Post by kostby »
Welcome to GenVibe!
