Quote, originally posted by tiiguy »(you'll need the wiring diagram showing its placement since you still can't really see too clearly)if anyone is looking for it, tribalman posted a diagram in
http://forums.genvibe.com/zerothread?id=39007 that highlights the starter relay location (on the top side of the under dash fuse block)Quote, originally posted by ThunderScout »Where did you locate the starter solenoid?  I am having same trouble with my car - it will not crank.  We have already replaced the starter relay and that fixed the problem for about 2 days. Now we are at the same issue and I cannot think it would be the relay again. We have had the starter checked and it is fine.  I am thinking the solenoid or starter switch.  If you can help me out, I would greatly appreciate it. CAPwelcome to genvibe.  what year Vibe do you have, and is is a manual or auto trannsmission model?  Does the car make any sound when you turn the key to the start position?The starter solenoid is attached to the starter motor.  If you were to buy a replacement starter, it would come with a solenoid attached, but it looks like you can buy a replacement solenoid without having to buy a whole new starter.  Here's a pic of a 2003 Vibe starter, probably the same exact part number for 2003-2008, not sure about 2009-2010 vibes, but they should all  look/behave the same. When the starter relay applies power, the starter solenoid kicks a gear on the starter motor to where it engages with the gear teeth on the outside of the flywheel, then the starter motor spins, and it turns the engine over.  When the starter relay cuts power, the solenoid pulls the gear back away from the flywheel and power is cut to the starter motor.  I can't remember if the power is applied to the starter motor only when the solenoid is engaged, seems like that would make sense to keep the starter from spinning before it's gear meshed with the flywheel.My '03 vibe has a manual transmission, so far the only problem I ever had getting the starter to kick in was because of having to really mash the clutch pedal to the floor to hit to hit clutch-to-start switch.
