Ok, I have 2 relatively good sounding 6 inch speakers that were given to me in a nice box. I was just trying to figure out how to wire the new speakers to the stock amp. I have a 05 base of course. I've looked under the passenger seat and all I found was a super small box with two wiring harnesses coming off the front, the one on the right, white with multi colored wires, and the left one with a black harness with more multi colored wires. Is this the stock amp? If yes, how could I go about hooking up the new speakers to the stock amp. I know i'll have to splice wires cause I want to wire them to the existing left and right rear wires. The new speakers are in a box as I said and have the red and black positive and negative on the back so I'm just looking for the location to wire the speakers by simply plugging the positive and negative into the box after I splice some wires and run them to the back of the car. I'm just needing some general help.
2005 Vibe Base 148k milesK&N Air Filter in stock boxCustom Painted interiorCustom Painted Engine BayAftermarket driving lightsMuch more to come http://forums.genvibe.com/zerothread?id=42124
"Don't look to the government to solve your problems, the government is the problem." Ronald Reagan"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety." Ben Franklin.
then I guess my question moves to other than running a wire from the rear door speakers to the other speakers in the back in the box, what are my options?
time to venture into the ole door panel Or pull your stereo out and tap into left/right from there. And run your speaker wire to the back (should be a breeze to hide)
Quote, originally posted by K-NINE »I don't think the base model has an amp.i have a base vibe which has moons and tunes and there is an amp under the passenger side seat.here is the moons and tunes wiring diagram http://forums.genvibe.com/zero...o.gif
I just went into the door panels and spliced the wires to the speakers in the back. It'll do until I get a small amp and have them independently ran.
