How to: Remove Front Fascia (for 09)
vibedrivermatt
Post by vibedrivermatt »
thread removed by vibedrivermatt. maybe will put back up a neater more edited version later.
keithvibe
Re: How to: Remove Front Fascia (vibedrivermatt)
Post by keithvibe »
Quote, originally posted by vibedrivermatt »and... what is this??two very small white and blue wires run to a small connector that goes to nowhere and is clipped to the car near the bottom of the rad. hmmmmmm? interesting. temp sensor...
vibedrivermatt
Re: How to: Remove Front Fascia (keithvibe)
oh really? I did not know this.
cq358
Post by cq358 »
are you contemplating buying a set of oem fog?You can get turn signal switch from Rock auto around 90 bucks
vibedrivermatt
Re: How to: Remove Front Fascia (cq358)
Quote, originally posted by cq358 »are you contemplating buying a set of oem fog?You can get turn signal switch from Rock auto around 90 bucksyouknow actually I wanted to get some PIAA 410's. It would be cool if I could have them hooked up OEM style though. I just don't know how possible that is. Thanks for the information though!
cq358
Post by cq358 »
Your write up is clear and full of pictures. keep up the good work.I am from Canada. Rockauto is the only place that their shipping included duty and custom broker fees. If any part you received is defective they will refund everything (incl shipping). I guess they uses FedEx Ground instead of UPS..
