I have a 2005 Vibe. The headlamp lens has come loose from the rest of the housing (you can grab the bulb connector and wiggle the lens around in the housing). 1. What holds the lens in the housing and 2. If I remove the assembly and open it, would it be repairable or is replacement a better option? Thanks!
2005 and 2008 base Vibes,1996 Geo Prizm (traded)Nummi, nummi, nummi....
speaking from a guy who has opened up several headlights, my guess is the reflector bucket poped out of the ballsocket that it pivots on when an adjustment is made.You have two options.one, remove headlight from car, bake it open and see if it's repairabletwo, remove headlight from car, replace with ebay fine. <<<easier
Thanks! Sorry, it took me awhile to get back here. I ended up back at Carmax and somehow they seemed to have fixed it... maybe you can pop the lens back in the socket without a disassembly??
