2003 Vibe Power Lock Actuator Problems
TS03Vibe
Post by TS03Vibe »
I have a 2003 Vibe. The front and rear driver side power locks are not working. I can lock and unlock manually, but the power actuators are not working.New oem actuators are very expensive ($300 or more).I haven't had much success finding used actuators for my 2003 Vibe.A1 Electronic sells a universal MES Door Lock Actuator (2 wire-cable) that will work with cable actuated lock systems, like the Vibe. Has anyone tried a universal power actuator, like this one from A1 Electronic? At roughly $20, it is tempting to try it. Can I simply unplug the wires from old actuator, install this universal one, and then connect the the new actuator to the same 2 wires that powered the original oem actuator? Thanks for any help or advice on how to repair/replace the bad actuators.See universal actuator here: http://www.a1electric.com/Merc...=W15C
cptnsolo77
Re: 2003 Vibe Power Lock Actuator Problems (TS03Vibe)
Post by cptnsolo77 »
I have a similar problems & have ben looking for help as well. This is my thread & I found a post where someone opened up the actuator & cleaned it out with electrical contact cleaner.http://forums.genvibe.com/zerothread?id=42459Keep us posted if you find anything.Actuators are NOT cheap!!!
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
