the 2nd gen vibe owners will answer soon, but if its lke my o4, the cabin air filter is behind the glove compartment. there should be 1 screw where the glove compartment hinge is. take that off, and right behind it, flip the lid and pulll out the filter.used the search and found this:http://forums.genvibe.com/zerothread?id=982&page=1again generation 1 vibes, but should be very similargood luck!!!!!
de-badged o4 vibe
o2 triumph speed four
it's in the same place in the second gen vibes, but there's no screws to remove. just pull in on either side of the glove box to release it from the dash
1992 Chevrolet Camaro RS 305/5-speed, Bright Dark Teal
2009 Pontiac Vibe Base 1.8L/5-speed, Carbon Grey
Open the glovebox. Push the flexable sides of the glovebox in and lower the it as far as it'll go. Look inside to the left and remove the little cover!
