Accessory drive belt
dzknmd1
Post by dzknmd1 »
The belt listed for both of my Vibes is a six groove belt that is 72.5" long. Checking my parts inventory I happen to have on hand a six groove belt that is 73.5". I do not need to replace a belt at this time. However, I was wondering if anyone here has enough experience with this to advise me as to whether I can use the belt I have without any problems.
ou.grizzly
Re: Accessory drive belt (dzknmd1)
Post by ou.grizzly »
The belt in your inventory is too long, need to stick with the exact measurements, especially since belts tend to stretch over time. My thoughts, if you were to put that belt on, it would not stay on.
dzknmd1
Re: Accessory drive belt (ou.grizzly)
Post by dzknmd1 »
Thanks for the quick reply. I thought that might be the answer but I wanted to run it past you guys anyway. I won't waste my time with it then.
jake75
Post by jake75 »
Cut out an inch and use Krazy Glue to put it back together - I hear that stuff holds 2 tons.
dzknmd1
Re: Accessory drive belt (jake75)
Post by dzknmd1 »
Quote, originally posted by jake75 »Cut out an inch and use Krazy Glue to put it back together - I hear that stuff holds 2 tons.Now that's thinkin' outside the box.
jake75
Post by jake75 »
I try my best to keep you folks entertained!
ou.grizzly
Quote, originally posted by jake75 »I try my best to keep you folks entertained! Do you do parties?
Whelan
Post by Whelan »
Go for the Goodyear Gatorback. I installed mine at around 50-60,000 and am currently at 116,000 with no wear on the belt showing.
2012 GLI Autobahn 6MT
Water boy
Re: Accessory drive belt (Whelan)
Post by Water boy »
Quote, originally posted by Whelan »Go for the Goodyear Gatorback. I installed mine at around 50-60,000 and am currently at 116,000 with no wear on the belt showing.+1 on GatorBack
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
106,019 Yokohama YK580 205/55-16 $589.19 drive out
ou.grizzly
Re: Accessory drive belt (Water boy)
What is the warranty on the gatorback?
Water boy
Post by Water boy »
I'm on various auto related forums and the GB has high recommendations and not one failure reported.In other words... it does not matter.
2008
70,395 Battery
dzknmd1
Post by dzknmd1 »
The one I am going to cut out an inch and glue together happens to be a Dayco.
zionzr2
Post by zionzr2 »
I have and recommend the GatorBack Belts as well
