what is it and what does it hook to.
scherry2
Post by scherry2 »
looked under my dash today and the cable that hooks to the back side of the radio bezel just below the a/c and recirc button is unhooked i have no idea where it hooks up to anybody got a clue? its the yellow plastic in the pic
bodhi_tree777
Re: what is it and what does it hook to. (scherry2)
Post by bodhi_tree777 »
Quote, originally posted by scherry2 »looked under my dash today and the cable that hooks to the back side of the radio bezel just below the a/c and recirc button is unhooked i have no idea where it hooks up to anybody got a clue? its the yellow plastic in the picHmm. My brother owns a car stereo shop, when I got the Vibe he mentioned having installed a head unit once in a similar car and he ran into a mystery cable in that very same area. I know that doesn't answer your question, but at least you're not alone
06pvibe
Post by 06pvibe »
See when it's hot and when its not. It could also be for the Moon & Tunes amplifier for the sub amp?
bodhi_tree777
Re: what is it and what does it hook to. (06pvibe)
Quote, originally posted by 06pvibe »See when it's hot and when its not. It could also be for the Moon & Tunes amplifier for the sub amp?that makes sense. That connector could be part of the stock wiring harness for all vibes, but if you're not equipped with M&T it just hangs there.
hard to tell for sure because the connector is kinda blurry.If it is just a one pin connector, then it could be the one that provides power to the antenna, especially if the one wire going to it is in a loose plastic sleeve. If it's two pins, it could be the one that automatically turns on the AC when you have the air direction control set to half or full defrost.how many wires go to the connector, and what colors are those wires?
scherry2
Re: (joatmon)
Post by scherry2 »
its a cable not wiring it plugs in on one end behind the radio bezel below the recirc button. i'm sure it has to do with the A/C/ unit and the doors.
06pvibe
Re: (joatmon)
Post by 06pvibe »
Quote, originally posted by joatmon »hard to tell for sure because the connector is kinda blurry.If it is just a one pin connector, then it could be the one that provides power to the antenna, especially if the one wire going to it is in a loose plastic sleeve. If it's two pins, it could be the one that automatically turns on the AC when you have the air direction control set to half or full defrost.how many wires go to the connector, and what colors are those wires?Power antenna? On a Vibe? Actually, I thought that at first too, but since the antenna is in the middle of the roof I thought it unlikely. That's when I thought it might be the trigger (on) wire for a M&T Sub amp.Quote, originally posted by scherry2 »its a cable not wiring it plugs in on one end behind the radio bezel below the recirc button. i'm sure it has to do with the A/C/ unit and the doors.Did the Vibe/Matrix ever come with automatic climate control as an option? If so, then you may be correct.
Re: (scherry2)
Quote, originally posted by scherry2 » i'm sure it has to do with the A/C/ unit and the doors.Yeppers... This is what forces the recirc off when you move the mode knob to floor/defrost or defrost.One end of that (the white side) goes on the recirc switch on the bezel and the other end clips somewhere onto the HVAC control assembly. It's been a while since I've seen one apart but I would look for it to attach somewhere on the side where the mode knob is.
Re: (06pvibe)
I'd just leave it out. I almost never use the recirc function, and I've got that cable disconnected on the radio bezel side. I've also got the auto ac on defrost wire disconnected. (When it comes to the car, I like to be in control)If you want to hook it back up, you can probably get it back on by pulling the radio and working from there. Quote, originally posted by 06pvibe »Power antenna? On a Vibe? Vibes have an antenna amplifier built in to the base of the antenna, it gets power from a connection behind the radio
06pvibe
Re: (joatmon)
Post by 06pvibe »
Quote, originally posted by joatmon »Vibes have an antenna amplifier built in to the base of the antenna, it gets power from a connection behind the radioAh. THAT kind of power antenna. 'Makes sense.
scherry2
Re: (ColonelPanic)
Post by scherry2 »
well i have the dash all taken apart and cannot for the life of me figure out where it attaches for the recirculate door. I cant find my 03 service manual i had on disc. anyone want to look under thir dash for an old man and see if they can take a pic or bring me up a page from the sevice manual that thells where the yellow end clips in on the A/C? I'm begging here.
