Polk Audio db6501 and Moon & Tunes
cptnsolo77
Post by cptnsolo77 »
Anyone run these Polks with the factory Moon & Tunes amp? The Polks are rated 10 - 100 watts RMS & have a 92dB sensitivity rating. The Moon & Tunes amp is PROBABLY around 10-11 watts RMS.Will the factory M & T will be enough to power these speakers? Looks like from the numbers it will barely make it LOL.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
BlueCrush
Re: Polk Audio db6501 and Moon & Tunes (cptnsolo77)
Post by BlueCrush »
I thought the M&T amp under the passenger's seat only powered the Subwoofer in the rear...? I'm probably wrong though since I'm not an audio guru.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
cptnsolo77
The 2003 didnt offer a sub. I beleive it was 2005 when they started. I have the 200W ( peak ) factory amp that powers 6 speakers.....2 tweets & 4 door speakers.
kostby
Post by kostby »
FWIW: The factory speakers are 2-ohms, and that's what the "200-watt Amp" rating is based on. Probably more like 100-watt output to 4-ohm, and 50-watt output to 8 ohm speakers. Maybe less.
cptnsolo77
Wow...I didnt even think about that. Would that 50 watts be RMS?
rocket9005
Re: (kostby)
Post by rocket9005 »
The M&T amp is under the passenger seat. It is 6 channels. Two power the subwoofer in the back (dual voice coils), 1 channel each for the 2 rear doors, and 1 channel each for the front doors. the tweeters in the sail panels run of the front door, with a capacitor crossover to keep too much bass out of them.
2005 Base Vibe, 5 spd, NeptuneMoon & TunesPower Windows & Door LocksAlloy WheelsStill No mods (yet)
