Fog lights came in today!
Pudntain
Post by Pudntain »
Got the grilles from gmpartsdirect, part numbers are on a thread here somewhere. The trick is where to get the lights. GM wanted 90+ each without wiring. Did some research, there are a lot, a lot of toyotas that use the same light. Found a set with wiring for a 08 camry for $52. The grilles and lights are in, but run out of daylight before I could start wiring. Will wire them to a switch on the panel to the left of the steering column. Will tie them in to the parking lights so they will only function when parking lights are on, but also will be able to turn them off during the day. Only got pick of one side before it got dark, will post before and after.
Pudntain
Re: Fog lights came in today! (Pudntain)
Post by Pudntain »
Here is the after, toyota lights fit perfect. Will post after i get the wire done, let you know what kind of a nightmare that is.
Looks great ! You're definitely off to a great start with your Vibe! You should start a Garage thread for it so we can keep tabs on your progress .
morbay
Post by morbay »
That looks great, I wouldn't mind doing that to mine. Where did you pick up the set for $52?
Rob Pettigrew2009 Ultra White 2.4 AWDPearl White Arrowhead overlaysPainted Calipers October 2010 MOTM
ponta2147
Post by ponta2147 »
Hooray for adding fog lights!
Quote, originally posted by Pudntain »Here is the after, toyota lights fit perfect. Will post after i get the wire done, let you know what kind of a nightmare that is. Nice job Now it's time to tackle a few more SERIOUS mods !!! This site has a way of doing that to us members. I want to dig into my next mod Sooooo bad but have to wait till the fall when I know I'll have the time to follow through & finish Then there will be Santa's workshop where I know I'll be EXTREMELY busy
Pudntain
Re: (ponta2147)
Post by Pudntain »
got the lights on ebay, free shipping too. they have more.....Sabersport ebay store 07-09 camry. actually comes with the camry grills, wiring and dash switch.
Re: (Pudntain)
$52!!! Nice deal!!!
Kincaid
Post by Kincaid »
Pudntain - how did you access the old grille blanks? Do you have to drop the cover that runs below the bumper cover?
Re: (Kincaid)
Quote, originally posted by Kincaid » Do you have to drop the cover that runs below the bumper cover?I never did. Unless your model of Vibe had extra plastic down there.You can reach up from under the bumper and push the tabs in and push forward and it will begin to pop out. There are 5 I believe, havn't had mine off in a while but I recall them being stubborn... The wiring is neatly tied up right there as well.
Pudntain
Re: (star_deceiver)
Post by Pudntain »
There is a cover, three bolt/screws, drops down from the front, I think it goes up and is part of the wheel well cover too. Then reach in and release the five tabs.
vibedrivermatt
Re: (Pudntain)
Post by vibedrivermatt »
cool! You know you probably shouldn't need that wiring though. Vibes come pre wired for the fogs so you should just be able to plug them in. Then you just gotta figure out how to hook up that dash switch. Theres a thread about it on here I think the Speedeng guy did it
Kincaid
Post by Kincaid »
Yes he did - I believe he was the first.
