Very rough idle, engine cuts out at 3000rpm
matty77
Post by matty77 »
Here is the problem,I have been running with a bad donut gasket and I am wondering if that finally totally failed and has now caused an abnormal amount of air in the exhaust causing the sensors to malfunction. The idle is very rough, if I hold the rpms at 2500 and runs fine when in neutral. I can get through the gears when driving but once I go over 3000rm the engine cuts itself out, I had the exhaust system repalce three years ago, and at this time they changed all donut gaskets etc. spark plugs are 1 year old, The other possible issue could be that I went through a touchless car wash today, it does spray under the car and wonder if water contaminated something. thanks
2003 Vibe GTShawdowFactory AlarmSunroof
BlueCrush
Re: Very rough idle, engine cuts out at 3000rpm (matty77)
Post by BlueCrush »
Typically, the engine cutting out at 3K rpm means your MAF sensor is fried like most people do by mistake when the install an aftermarket intake. Any CEL?
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
scherry2
Re: Very rough idle, engine cuts out at 3000rpm (BlueCrush)
Post by scherry2 »
what he said. I've been thru 2.
matty77
Post by matty77 »
yes check engine light is on, I have not changed intake
lovemyraffe
Post by lovemyraffe »
I agree. It is probably the MAF. If the MAF is fried, the car will go into limp mode and will not allow you to rev the motor above 3,000. Even though you didn't change the intake, or maybe not even the battery, look at this: http://forums.genvibe.com/zerothread?id=39550
BlueCrush
Post by BlueCrush »
Before wasting money on doing anything, get the CEL code read. It is possible that the water may have shorted it out....maybe, if there was a bad(exposed) wire.
My Fleet:
matty77
Post by matty77 »
Well it would seem that 2 coils are not fireing, Mechanic fixed my exhaust problem, car is now purring but the same rough ride continues. They had the coils out and put them on the bench, no spark or very little on two of them, he only changed me for the exhaust work so I found some coils and will pick them up tomorrow and try and fix this car. Still in the back of my mind I think the car wash was the ultimate cause of this.
