Shift pattern for 6 speed?
mntn-biker
Post by mntn-biker »
Swapping out the 5 speed for a 6 speed this weekend. Anyone have a picture or can describe the shift pattern for the 6 speed? Probably gonna buy an aftermarket shift knob to replace the 5 speed knob.I can pretty much guess the number pattern but uncertain of where the reverse position is:1 up and left2 down and left3 up and middle4 down and middle5 up and right6 down and rightR = ???Thanks - Mike
2003 base model
Neouka
Re: Shift pattern for 6 speed? (mntn-biker)
Post by Neouka »
let me know how this goes, my 5 sp trans is on its way out and I'm also wanting to do the 6sp swap very soon (I can get a 6sp trans for cheaper anyway)IIRC, reverse on the 6 speeds is even more left-er and up
03 Abyss Base, not 5 .. 6spd!2012 Focus soon...
mntn-biker
Re: Shift pattern for 6 speed? (Neouka)
Here is a great how-to link for pulling a trans. This is what I will be using as a guide this weekend.Thx for the info on the shift pattern... http://wehavescissors.blogspot....html
2003 base model
Old Tele man
Post by Old Tele man »
...see page 2-26 in the 2003 Owners Manual located here:http://forums.genvibe.com/zerothread?id=1010...REV is all the way LEFT, then FWD/UP.
...and the Devil said: "...yes, but it's a DRY heat!"
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
mntn-biker
Re: (Old Tele man)
Quote, originally posted by Old Tele man »...see page 2-26 in the 2003 Owners Manual located here:http://forums.genvibe.com/zerothread?id=1010...REV is all the way LEFT, then FWD/UP.Guess I should have checked the manual but most times there is not much useful information in it...Thanks to all for the info!
2003 base model
Neouka
Post by Neouka »
done your swap yet?I'm still having to do this soon. I found a used 6sp transmission, but don't want to buy it yet until I know it works for sure
mntn-biker
Re: (Neouka)
Quote, originally posted by Neouka »done your swap yet?I'm still having to do this soon. I found a used 6sp transmission, but don't want to buy it yet until I know it works for sure Have it all torn apart. Just got the flywheel back from having it re-surfaced. Will start putting things back together this week. Not looking forward to stabbing the 6 speed onto the engine. When taking the 5 speed out, things got a little dicey with my floor jack and the cradle I made from 2x4's etc. Definately going to be a 2 person job stabbing the trans onto the engine....
2003 base model
