Am I missing anything here ....???
Water boy
Post by Water boy »
Here are some pics of what could be something missing.The 2008 had the front end replaced by a 5-star body shop.Boy did I find lots of stuff missing or installed sloppy.This is 1 of the 2 threaded holes in the cross brace in front of the radiator.Looks like something should be attached using these 2 holes.This is towards the head light. Just a hole plus a matching one on the other side.This is on the trailing edge of the fender before the tire. It has a metal strap thingy with 2 threaded holes.
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
106,019 Yokohama YK580 205/55-16 $589.19 drive out
Re: Am I missing anything here ....??? (Water boy)
If there was something there you should see a circular mark where the bolt was seated against the crossmember and possibly a mark of the outline of whatever was attached.If the threaded hole is rust free then there was probably a bolt there. If the threaded hole's rusted up then nothing was used in that space.Was that crossbrace repainted?
Water boy
Re: Am I missing anything here ....??? (star_deceiver)
Post by Water boy »
Quote, originally posted by star_deceiver »If there was something there you should see a circular mark where the bolt was seated against the crossmember and possibly a mark of the outline of whatever was attached.If the threaded hole is rust free then there was probably a bolt there. If the threaded hole's rusted up then nothing was used in that space.Was that crossbrace repainted?I understand your questions.Under normal situation I could answer the questions.The thing is that all of the front sheetmetal was replaced so I have no idea what is "supposed" to have some thing attached.I'm thinking that the body shop shaved some corners thinking I won't miss it.
2008
70,395 Battery
djkeev
Post by djkeev »
Aghhh!! Don't get me started on Auto Repair "professionals"!!!!!!!!!!!!!!!!!!Go to you local used car lot, maybe even your old Pontiac dealer and explain your situation and ask if they would mind if you looked at a Vibe they had on the lot just to compare with.In the interest of future customer goodwill I cannot imagine a dealer saying no to such a request. I guess the possibility exists that you will steal some parts and that would be the only trip up.Dave
(o ! /o) (o)=I=(o)
djkeev
Post by djkeev »
Hi, I just snapped a bunch of photos of my 07, never been wrecked, essentially the same car as yours.Yes, you are missing some parts underneath.Send me you email address and I'll send you about 10 photos of my engine bay and under carriage.Davedkeevil@verizon.net
(o ! /o) (o)=I=(o)
Here's a few pics of some front ends... anything pop out at you???
Kincaid
Post by Kincaid »
some holes may just be for access - but good to have someone with an unmolested model to compare!
waveresponder
Post by waveresponder »
first two pics look fine to me IMO, third pic im not sure. if you look at the first wave blue vibe pic you can see that there are two threaded holes (one on each side of the sticker/decal) that are apparently used for nothingmust paint engine cover...
