MPG?
aussiemom
MPG?
Post by aussiemom »
I have an '03 and it is averaging 24-28 mpg. Is this normal? My mechanic said I should be getting close to 32 mpg with it. Two days a week I make a two drive (one hour there and back) to school and the other three days I just drive to work which is only about 7 miles one way. My computer is not showing any codes. It has about 130,000 miles on it...I think. In the winter everybody told me it's the cold. Well it's been warm out and I'm still not getting close to the 32 mpg.
ponta2147
Re: MPG? (aussiemom)
Post by ponta2147 »
Are your tires filled properly? I know when my tires were low it cut 2-3mpg off my averages (I have an '09 but I think this is basically a rule for all cars).
aussiemom
Re: MPG? (ponta2147)
Post by aussiemom »
Ya checked them. They are right where they should be. I did just check my mileaged and my car had 160,000 on it instead of the 130,000 I thought it had. I even did the whole injector cleaner the last oil change and no change.
GMJAP
Post by GMJAP »
With an auto a decent average MPG is around 29MPG. Cold will reduce mileage, and the short drives to work won't have very good mileage (bringing down the average). When was the last time the oil was changed?
aussiemom
Re: MPG? (GMJAP)
Post by aussiemom »
2500 miles ago. I change my oil every 3000. I am actually changing it this week again. I am going to change the plugs, wires, and fuel filter this week as well. I am also going to try running a few tanks of better gas thru to see if that helps. I don't mind the 29 mpg but when it goes down to 24mpg that really doesn't make me happy.
ramenboy...
Post by ramenboy... »
you won't see great mpg with really short trips. also, when you're on the two hour trips, try keeping the rpms down below 3000, and use your cruise control... when i'm doing a regular week of mixed driving, its normal to see 29-30mpg, sometimes less when its all short trips in the city.
de-badged o4 vibe
o2 triumph speed four
lovemyraffe
Post by lovemyraffe »
Quote, originally posted by aussiemom »I have an '02 and it is averaging 24-28 mpg. I'm guessing that you have an '03 instead of an '02. I think that 28 is a little low. I do a lot of stop and go driving and usually get 32-34.
aussiemom
Re: MPG? (lovemyraffe)
Post by aussiemom »
It is an '03! I forgot to make that change. For giggles on one tank of gas I set the cruise at 65 to and from school both trips and limited my short trips and only got one mpg better. I just find it really strange that I can't control the gas mileage. I still owe on this car and really can't afford to get another one till this one is paid off. So I am trying to make the best of it and do what I can to improve the gas mileage.
ou.grizzly
Post by ou.grizzly »
AWD or FWD?
aussiemom
Re: MPG? (ou.grizzly)
Post by aussiemom »
FWD
ramenboy...
you can try cleaning the maf sensor. takes maybe 15 minutes, tops, to me, it definitely helps, and as groucho marx would say 'it couldn't hoit.'the spray cleaner costs about $8. you can get it at any auto parts store...its only 2 philips screws to remove the maf from the air filter unit.will post the the DIY when i find it
de-badged o4 vibe
ramenboy...
ok try thishttp://forums.genvibe.com/zero...49076
de-badged o4 vibe
DoubleBaril
Post by DoubleBaril »
Would be nice to get 24 mpg!
2003 Vibe AWD
aussiemom
Re: (DoubleBaril)
Post by aussiemom »
I changed the plugs and cleaned the MAF sensor so will see if that helps. The plugs and coils are Denso that are in my car so I'm assuming they were origional equipment? The auto parts store didn't have them so I got NGKs instead.
AdmRose
Post by AdmRose »
I average 30 MPG in my '04 AWD (doing 90% - 95% highway mind you) so you should have no problems getting more than that in a '03 FWD.
2004 AWD Vibe - "The Indignant"- Traded in 7/9/12
2010 Honda Insight EX - Current ride
sikvibe
Post by sikvibe »
I can still pull 28 mpg's if i stay off the throttle..before I started modding I was getting 32 though...
*03 SIKVIBE*Performance mods in order:18x8 Konig illusion rims w/ falken ziex 235/40R18 tires~1.5" lowered TEIN S. tech springs~GM performance parts supercharger~TRD add-on ECU for S/C~Drop in spectre high flow air filter~Tripod center dash oil pres.,egt/boost, a/f guage pod~Homemade .5" custom S/C thermal intake spacer~1.9" aluminum S/C pulley~150 psi>530cc nozzle water/alcohol injection system~2.5" single cat proflow muffler opposite exit install
BrettZ
Re: (aussiemom)
Post by BrettZ »
Quote, originally posted by aussiemom »I changed the plugs and cleaned the MAF sensor so will see if that helps. The plugs and coils are Denso that are in my car so I'm assuming they were origional equipment? The auto parts store didn't have them so I got NGKs instead. Hows the mileage going?even on my 05 base I get 26-27mpg with a majority of short 10-15min city trips
Everything that we see is a shadow cast by that which we do not see. - Martin Luther King, Jr.
Kamikaze
Post by Kamikaze »
I'm anywhere from 20-30mpgs one thing that could be the issue is your catalytic converter, some other guys could probably chime in about this one b/c mine was too new for the recall.
August 2009 VOTM Click HERE for my Garage
ClunkClunk
Post by ClunkClunk »
I have a 2008. Automatic. 1.8L base engine. ~45k miles.In the past 18K miles (since I bought the car) I've been tracking every single drop of gas that's entered it. I'm currently at 29.3 MPG overall.
2008 Frosty two tone (and 3 other Vibes)
DiveNut
Post by DiveNut »
That seems about right for around town type driving. It really depends on you driving style...I average 27-29 around town when I keep my foot of the loud pedal. Get 20-22 when driving a bit more spirited... What are you averaging on the highway?
Bare Bones Base, Abyss 2004 Vibe, Debadged, Auto, ABS, GM Performance Supercharger, Injen CAI, 2.3" URD Pulley, Unichip,Tru-Cool Tranny Cooler SOLD
1972 Plymouth Duster 340 (Strip/Street Project)
Old Tele man
Post by Old Tele man »
...MPG is the final result of MANY singular things:* you don't get 100% mpg until engine is 100% warmed up, which typically takes about one-half hour.* you don't get 100% mpg unless you're in highest manual gear or automatic is in "lockup," which is >40mph until warmed up and then >35mph thereafter.* you don't get ANY mpg stopped at a light, where you're eating gas, but getting NO miles.* going UP hills eats gas; going DOWN hills doesn't (only idle consumption).* you loose mpg everytime a truck (or car) drives along side you; but you gain mpg when you "draft" a truck (or car).* constant, slower, speeds are much more fuel efficient that faster, "rubber-banding" traffic flows (fast-slow-fast-slow, etc.).* it takes MORE gasoline to accelerate than it does to maintain the same speed.* A/C cuts your mpg, use it sparingly....on the freeway at 65mph, I get almost 37mpg in my '09 Vibe base without A/C; but, only about 35 with the A/C on...EPA ratings are 25-31mpg, so I'm obviously doing much better than their tests.
...and the Devil said: "...yes, but it's a DRY heat!"
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
cptnsolo77
Post by cptnsolo77 »
Im getting about 28MPG city/highway. AC is almost ALWAYS on. South Florida is not very forgiving. I run my tire pressure @ 38 PSI all around & run a K&N drop in filter. I use cruise whenever possible....even down a 45 MPH stretch lol. To me your MPG sounds about right. I was a little disapointed in the Vibes milage initially, but my previous car was a Honda Civic & I got close to 40 MPG....but the Vibe is a a little heavier than the Civic, so I justified it that way lol.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
WooTinn
Post by WooTinn »
I'm not getting amazing gas mileage either. Lower than 300 miles to a tank. But my check engine light is on for a "Catalyst Efficiency Below Threshold" code.Could my gas mileage be improved with a new converter?
2003 Neptune Base1ZZ-FE 5 SpeedNeptune / GrayInvoluntary Custom body + suspension work :/35w HID's2 12" Rockford Fosgate P1's500w Rockford Fosgate Prime amp
Old Tele man
...here's what we're getting:2004 (wife's) Vibe 1.8L, auto: ~ 31 mpg, mostly city, a/c always on.2009 (mine) Vibe 1.8L, auto: ~ 35 mpg, mostly highway, a/c only in afternoon.
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
djkeev
Post by djkeev »
My 07 1.8 auto with ac gives me a constant 28 MPG in combined driving, rarely it is 26. On a trip I can count on 32 and have gotten as good as 36.Dave
(o ! /o) (o)=I=(o)
DoubleBaril
I'm averaging 21.6 MPG in my 03 AWD (and pretty much 100% city)New NGK Iridium plugs, Cosmo SRI, Cleaned the MAF, and the Catalytic Converter is fine.
2003 Vibe AWD
