fwd to awd conversion!?
sikvibe
Post by sikvibe »
Has any one converted the front wheel drive to the awd? After having some pretty bad wheel hop at the dragway this weekend im looking for more traction..does anyone know what hp its good for?
*03 SIKVIBE*Performance mods in order:18x8 Konig illusion rims w/ falken ziex 235/40R18 tires~1.5" lowered TEIN S. tech springs~GM performance parts supercharger~TRD add-on ECU for S/C~Drop in spectre high flow air filter~Tripod center dash oil pres.,egt/boost, a/f guage pod~Homemade .5" custom S/C thermal intake spacer~1.9" aluminum S/C pulley~150 psi>530cc nozzle water/alcohol injection system~2.5" single cat proflow muffler opposite exit install
AdmRose
Re: fwd to awd conversion!? (sikvibe)
Post by AdmRose »
Far as I know the AWD and base use the same engine, the 129 (?) HP 1ZZ.
2004 AWD Vibe - "The Indignant"- Traded in 7/9/12
2010 Honda Insight EX - Current ride
sikvibe
Post by sikvibe »
Yeap, it would be super easy, just a matter of switching transmissions and adding driveline, rear diff, and rear drive parts..has anyone ever done it?
ou.grizzly
Post by ou.grizzly »
Floor Pan / Sheet Metal on FWD does not have the hump to accommodate the extra parts like the AWD models
sikvibe
Re: fwd to awd conversion!? (ou.grizzly)
Post by sikvibe »
Are you sure because my exhaust currently resides in what looks like a perfect channel for a driveline??
ou.grizzly
Quote, originally posted by sikvibe »Are you sure because my exhaust currently resides in what looks like a perfect channel for a driveline??Does the floor of your Vibe in the back seat have a large center hump? And by the way, the 03-06 AWD from factory is SLOW
Bikerscum
Not going to help you at all but...
Post by Bikerscum »
I do remember a how to kinda post from someone going the other way. Do a search, maybe he can answer some ??'s
Do something a little diffrent and put another engine/tranny in the back to drive the rear wheels!!! Sure you'll lose a little cargo capacity and mileage and it'll be a lot of work but your power to weight ratio could nearly double!!!
BlueCrush
Post by BlueCrush »
Quote, originally posted by sikvibe »Has any one converted the front wheel drive to the awd? After having some pretty bad wheel hop at the dragway this weekend im looking for more traction..does anyone know what hp its good for?No, no one has done this. Different tranny, different driveline, drum brakes in rear. This will not solve your wheel hop problem. The AWD uses a viscous coupler that engages the rear wheels only after the front wheels are spinning and only puts down approx. 40% power to the rears. The AWD system would not be able to handle your S/C for long if you tracked it often. You would be better off buying an AWD if you want to go this route.BTW, Energy Suspension motor mounts are suppose to help with wheel hop.... But you know that already, right?
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
ou.grizzly
Re: fwd to awd conversion!? (BlueCrush)
Quote, originally posted by BlueCrush »No, no one has done this. Different tranny, different driveline, drum brakes in rear. This will not solve your wheel hop problem. The AWD uses a viscous coupler that engages the rear wheels only after the front wheels are spinning and only puts down approx. 40% power to the rears. The AWD system would not be able to handle your S/C for long if you tracked it often. You would be better off buying an AWD if you want to go this route.BTW, Energy Suspension motor mounts are suppose to help with wheel hop.... But you know that already, right?Just to clarify it more... 03-06 AWD has a different ECU, exhaust, and rear suspension. At the same time though, the 03-08 Base Vibe (ABS as an option) / 03-06 AWD (ABS standard) also had drum brakes.
northvibe
Post by northvibe »
get engine/trans mounts, traction bars, anything that will stop the engine from moving (which idk I'd recommend for dd'ing...). poly is kind of crap, but you'd want solid mounts if you want no wheel whop and just spin. Are you drag racing on slicks or just street tires?
sikvibe
Post by sikvibe »
Thanks for all of the helpful feedback you guys, after learning about how wimpy the awd is..the rwd coversion would be my only viable option for big power gains..I think I will try to get this fwd thing down first...
AKLGT
Post by AKLGT »
engine mounts and learn the car. it's no different from trying to drag an SRT4 or MS3. You just can't really launch the car hard or you'll have massive wheel spin and jerk.
AKLGT1998 Subaru 2.5RS
