The products found in this artical can be found at Classic Motoring Accessories.
http://www.properautocare.com Once you’ve selected a wax, here are some tips to make waxing easier:1. Always work in a shaded area. Elevated paint temperatures cause waxes to dry too quickly. this may cause hazing or streaking. 2. Apply waxes using as thin a coating as possible. 3. Remove wax and buff using clean, dry terry towels. Tightly woven material (like diapers) can trap particles between itself and the paint and cause fine scratches. New microfiber towels like the Magic Towel work unbelievably well as a final wipe towel. I keep one Magic Towel just for use as a final wipe towel and honestly believe that it creates a better shine. 4. If you have difficulty buffing the wax to a uniform shine, switch to a clean wipe towel. 5. Hazing, streaking, and uneven gloss can result from using too much wax or waxing a surface that’s too hot. If the gloss is uneven, mist the waxed surface with distilled water and re-wipe with a fresh towel. (A spray bottle with distilled water and 1/2 teaspoon of Isopropyl alcohol is a great solution for removing problem streaks and cloudy patches.) Eagle One Wet Wipe & Shine, Eimann Fabrik Clear Pearl, and Pinnacle Crystal Mist also work wonders on problem cars with streaking and uneven gloss. Simply mist the surface with one of these products and wipe with a clean towel. Show-Car TrickDetailers that prepare show cars will often layer a carnauba wax on top of a synthetic wax. The synthetic wax acts as a gloss layer while the carnauba wax adds depth and liquidity. One combination that works very well is an initial coating of Klasse All-In-One followed by one or more coats of Pinnacle Paste Glaz or Souveran wax. The Pinnacle waxes are super-pure carnauba waxes that can be layered without any yellowing effects.
