Ok - my install is done now I wanted to put some super, super noob tips up - this was the first time I'd ever installed, so I figure it might be handy to someone in my position next time.1. The factory brackets on the factory unit stay on the unit; don't try to adapt them to the new head unit. 2. Get a double din adapter kit from Crutchfield or somewhere. Chances are you are going to have to cut the adapter kit to shape. It comes with a lot of attachment options (unneeded mounting points in the mold) and you don't need all of them. Use a pair of pliers to snap off the ones you don't need and cut any bars out from the front of the kit if there is plastic running down the middle of the opening (across the front of your new stereo display).3. Good luck finding the parking brake wiring harness! I didn't I ended up getting a 12v relay and using it to bypass the parking brake sensor so that the unit plays video. (It's a pioneer AVH-3200BT) The install was rather simple, just remember, it's still illegal in most states to watch a movie while you are driving. And, really, watching Jurassic Park while doing 70, and texting, is not a good idea. (In any state, really )4. You may need to get some extra copper wire - you can buy some, or just hack apart an old AC power adapter for a computer accessory
USB 1.1 hub anyone? Worked great for running extra ground wire.5. Zip ties are handy
coil your extra cable length and put it back into the dash6. Routing a handsfree mic cable is easily done by pushing the cable into the weather stripping along the driver's side windshield pillar. You can drop the jack connector into the gap between the dash and the windshield. Reach back through and pull it out the front. I also found that you could push the cable down through the seam between the pillar and the dash, making it disappear almost completely. I then clipped the mic to the sun visor and zip-tied the cable to the hinge where the sun visor is attached. Also, at the top of the pillar between the plastic and the headliner there is a slight gap that the mic cable can be fit into.Hope this helps someone else in the future!
