Stereo/ Subs
2010VibeMan
Stereo/ Subs
Post by 2010VibeMan »
I have a 2010 Vibe GT and am currently working towards putting in 2 12" subs and an amplifier. Does anyone know if i need a new head unit or if the current stock reciever has the av input plug ins needed so that i can hook up the amplifier and subs right to the current stock unit??
VibeBear
Re: Stereo/ Subs (2010VibeMan)
Post by VibeBear »
the stock unit won't have the RCA pre-outs for an amp. Most amps have both Low Level (RCA) and High Level inputs (speaker output from factory head unit)or you can buy an adapter that converts the speaker output into an RCA connection: http://www.crutchfield.com/p_1...ssi=0
1992 Chevrolet Camaro RS 305/5-speed, Bright Dark Teal
2009 Pontiac Vibe Base 1.8L/5-speed, Carbon Grey
Mariachi
Post by Mariachi »
i myself have an adapter in my car currently. i am planning on an aftermarket double din though soon. i recommend getting an aftermarket deck though cuz the sound isn't as powerful with the adapter as it is direct coming from the rca outputs of the deck.
BlueVibe09
Post by BlueVibe09 »
I'd recommend an aftermarket HU as well. If you stick with OE head unit get a converter, it sounds better than using the speaker level inputs.
2009 Base 1.8 L-Midnight Blue Metallic -35/20 Tint -SONY XS-GTX1620S 6 1/2'' Component Speakers-Boss Bass 1200 low-profile powered Sub -DIY Heavy-Duty Rubber Cargo Mat-JDM Short Antenna -Partial De-Badge-aFe Pro Dry S filter - 16" Konig "Incident" rims
