What's the difference, and benefits of both an inline engine and one where they are staggered, or not inline, or whatever the proper term is?Not sure what the benefits, selling points, etc. are of each type of engine...
quote:Have you seen a inline 6 or a inline 8?I have... But I have never seen a v 4. They have been made; Saab had one in the '60's and '70's. And the flat 4's of Subaru, VW and Porsche are more or less just flattened V engines. I 'm pretty sure that there have even been V-2's produced in Europe.
XRS 6-speed, Cosmic Blue, 17's, AEM Short Ram, Hidden Hitch
quote:Have you seen a inline 6 or a inline 8?I have... But I have never seen a v 4. They have been made; Saab had one in the '60's and '70's. And the flat 4's of Subaru, VW and Porsche are more or less just flattened V engines. I 'm pretty sure that there have even been V-2's produced in Europe.Well I seen and worked on Twins or V 2's as you want to call them on lawnmowers and commercial units.. Great Engines.. Briggs/Honda/Wisconson Robin/Onan/Kaw's/Tech you name it man... Use to do it for a living.. Even seen a few Mistu's in my life time for Diesel Fuel Generators.. Harley, Honda, Yamaha, and Kawasaki also make quite a few V-twins as well. I was just thinking along auto lines.
V and W are cylinder arrangements. A V-type block (we'll use an 8 for example) would have 8 cylinders total, 4 on each side in a V shape. A W-type block (near as I know, Volkswagen exclusive) is like a double V. 2 cylinders per side of each V, 2 V's wide per block.V-Engine:http://auto.howstuffworks.com/engine-v.htm
quote:V and W are cylinder arrangements. A V-type block (we'll use an 8 for example) would have 8 cylinders total, 4 on each side in a V shape. A W-type block (near as I know, Volkswagen exclusive) is like a double V. 2 cylinders per side of each V, 2 V's wide per block.V-Engine:http://auto.howstuffworks.com/engine-v.htmdon't forget the wankel. lol
Too right! Forgot about that one.The lovely Wankel rotary. A marvel of low displacement horsepower, and extreme smoothness all rolled into one cute, cudly little package. Now replaced by Mazda's "Renesis". Let's hope it's all the engine the original was (providing it can continue to meet the US standards). Renesis Article (Sorry, it's Australian so the HP is in Kilowatts, but it's the best I could find that had photos...):http://www.autoweb.com.au/start_/showal ... ticle.html
This is ragingfish. This is ragingfish trying to understand how people describe inline vs non-inline engines. This is ragingfish begging someone to put it in plain english. Don't let the raging fish down!
inline engines tend to be not as smooth as a v block.when they first built engines they were inline, ie 4 cyl, 6 cyl and a straight 8. they were dependable easy to work on but long and tended to really pull to the right (or is it left) when running.then someone came up with the idea of putting 4 cyl next to 4 and you have a V8. 2 cyl will fire at almost the same time ( the firing order) tending to smooth out the engine and it was alot shorter so they could fit it into a smaller area. then someone came up with the wankel and it was a round engine with a triangle shape in the center with 3 firing chambers. the triangle was one of maybe 10 moving parts on the whole engine. Hope this helps
quote:inline engines tend to be not as smooth as a v block.Not totally correct. The I6 is the smoothest running engine around.quote:when they first built engines they were inline, ie 4 cyl, 6 cyl and a straight 8. they were dependable easy to work on but long and tended to really pull to the right (or is it left) when running.Incorrect. All engines torque over when running.quote:then someone came up with the idea of putting 4 cyl next to 4 and you have a V8. 2 cyl will fire at almost the same time ( the firing order) tending to smooth out the engineAgain, incorrect. First, 2 cylinders do not fire at the same time and it's the off firing order in a V engine that causes it not to be smooth. Get your facts straight before answering technical questions.
Actually, the V12 is considered to be one of the most balanced and smoothest engines. I6 do case some issues like being too long for some applications. For example, the 4.2 I6 from GM is a topic of conversation. Many want it to appear in other cars, but GM is faced with a few issues. First, the vehicle has to have a longer hood and second, in frontal collisions, the engine can penetrate teh firewall easily. This is probably why the Trailblazer is the only vehicle using this engine and not offered in the Colorado.
quote:Scherry2 was right about a inline engine has less moving parts...Scherry2 didn't say inline engines have less moving parts, he said:quote:the wankel and it was a round engine with a triangle shape in the center with 3 firing chambers. the triangle was one of maybe 10 moving parts on the whole engine.He was talking about a Wankel Rotary engine. Also, inline engines do not always have less moving parts compared to other types.quote:But the odd thing is, the first link states a V8 is smoother running than a 4 cylinder.Usually, V8's are smoother than inline 4 engines. However, some inline 4 engine have balance shafts that smooth them out. For the record, inline 6 and V12 engines (A V12 is really just 2 inline 6 engines together) are the most smooth naturally followed buy V8's and then 4 cylinder. However, engines with additional balance shafts can be smoother than other engines without balance shafts.
quote: Usually, V8's are smoother than inline 4 engines. However, some inline 4 engine have balance shafts that smooth them out. For the record, inline 6 and V12 engines (A V12 is really just 2 inline 6 engines together) are the most smooth naturally followed buy V8's and then 4 cylinder. if you check my first statement you will see that I stated that v8's were smoother than a inline 4. I was telling what I knew from experience in the automotive industry as a repairman since 1975 to 1990 (I am now in the Audit dept). as for ragingfish I think he only wanted to know in laymans term what the difference was. I don't think he is going to go out and buy a inline 12. nor pic up a "special" inline 4. then again all the jap motorcycle companys are now copying harley davidson and building the V-twin they must not like the smoothness of the inline 4.....................................................sorry, I apologize. I'm done
quote:if you check my first statement you will see that I stated that v8's were smoother than a inline 4.No you didn't. Go back and re-read your first post on this page it says and I quote:quote:inline engines tend to be not as smooth as a v block.No where did you say V8 or inline 4. You made a general statement about V engines being smoother than inline engines and that is an incorrect statement as inline 6 engines are the most smooth. That's all I was correcting.
The 4200 is a modular engine .In the Colorado they are just going to lop off a cylinder or two to have an inline 4 or 5 cylinder.Kind of like taking a northstar style setup and lopping off two cylinders and making the 3.5 liter v-6 engine in the auroras and intrigues.(I hear lately the 4200s are falling apart anyway)
