NOS
Supercharger, turbo, nitrous, and anything that has to do with forced induction
Amtron
NOS
Post by Amtron »
I know that a lot of people have talked about getting NOS, but has anyone put one on a Vibe on this site? I searched, but didn't find anyone who did anything more than talk about it.
satur9
Re: NOS (Amtron)
Post by satur9 »
ive had nitrous for about 5 years.try searching nitrous instead of nos.i know at least one other vibe had it aswell. 1zz 5 speed with 50 shot dynotune kit btw.click the link in my sig for some pics on my cardomain page.
Amtron
Re: NOS (satur9)
Post by Amtron »
Quote, originally posted by satur9 »ive had nitrous for about 5 years.try searching nitrous instead of nos.i know at least one other vibe had it aswell. 1zz 5 speed with 50 shot dynotune kit btw.click the link in my sig for some pics on my cardomain page.Yeah I searched nitrous, but I guess I didn't look enough.I checked out your page and it looks good . How much does it cost for a system? Is it hard to set up?Also I read that the most a 1zz engine should take is a 50 shot like u said, and the engine shouldn't need to be altered to be able to handle it. what rpm do u have it set at? Last question is does it give you good gains?
satur9
Re: NOS (Amtron)
Post by satur9 »
http://www.dynotunenitrous.com. great kit at great prices.50 shot is normaly safe some have been known to do 75.(1zz and 2zz celicas on http://www.newcelica.org).not to hard to setup but you have to buy an adaptor or cut fuel lines.its not like in the movies but a pretty good gain. you can walk 2zz's and bad drivers in faster cars.srt4's or cars that thought they were fast early 90 camaros rs. stock automatic mustangs
Amtron
Re: NOS (satur9)
Post by Amtron »
Quote, originally posted by satur9 »http://www.dynotunenitrous.com. great kit at great prices.50 shot is normaly safe some have been known to do 75.(1zz and 2zz celicas on http://www.newcelica.org).not to hard to setup but you have to buy an adaptor or cut fuel lines.its not like in the movies but a pretty good gain. you can walk 2zz's and bad drivers in faster cars.srt4's or cars that thought they were fast early 90 camaros rs. stock automatic mustangsPerfect, thanks! Which system did you buy?
northvibe
Post by northvibe »
Bluecrush had it or talked about using it.... instead of the SC. I know there were at least 2-3 people on the forum that had it I just cant remember who. A 50 shot is probably all you want to do though to keep on the safe side.
BlueCrush
Re: (northvibe)
Post by BlueCrush »
Quote, originally posted by northvibe »Bluecrush had it or talked about using it.... instead of the SC. I know there were at least 2-3 people on the forum that had it I just cant remember who. A 50 shot is probably all you want to do though to keep on the safe side. LOL! Talked about it only...never had nitrous or S/C on my vibe.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
THE VIBERATOR
Re: (BlueCrush)
Post by THE VIBERATOR »
BlueCrush! thats shameful
2003 Vibe Base - Sold2005 Corolla LE 5 speedcustom short ram air box6k HID kitIn memoriam of the Vibe, may you rest in peace:http://www.cardomain.com/ride/3168634
satur9
Post by satur9 »
dynotune system i posted the link
Amtron
Re: (satur9)
Post by Amtron »
Yeah, but there are two for the 4 cylinder engine. Is it the first or second? Like I mean there is one with bottle and bracket and then one without (both exactly the same other than that), and then a different system with and without bottle and bracket.
keithvibe
Re: (Amtron)
Post by keithvibe »
one is direct port one is a fogger kit.you want the fogger kit, unless you want to drill holes in your plastic intake LOLThis is a direct porthttp://www.dynotunenitrous.com...t=275 see all the nozzlesfogger dryhttp://www.dynotunenitrous.com...t=117fogger wethttp://www.dynotunenitrous.com...t=100don't forget the bottle warmerhttp://www.dynotunenitrous.com...ct=22and of course gauges Now do your homework for dry and wet LOLhttp://www.go-fast.org/z28/new_to_nitrous.htmlgranted this page is for corvettes but the basic's apply
rollavvti06
Post by rollavvti06 »
any way i can get a better look at how u tapped the fuel cause i have the kit and everything im just seeing at how i will make the fuel line work im a corolla btw but same everything as you
corolla supercharged
satur9
Re: (rollavvti06)
Post by satur9 »
i bought a billet aluminium fuel rail with extra ports.most people cut the fuel line use hose clamps and a tee right before the fuel rail.www.newcelica.org has plenty more info and pics. http://www.newcelica.org/forum...27456his tee is the red fitting by the battery. your battery wont be there but the fuel line is in same spot.you can also buy a custom fuel rail from mwr. http://www.newcelica.org/forum...smaay threre more pics/ intalls/info/options for rails on there. but that should get you started.go over there and do a search you get all the info you need.
kowell
Post by kowell »
NOS!It will give you on hell of a boost.... But only if you use the right kind...http://www.gixxer.com/forums/s...26570Epic Fail Inside
2009 Vibe 2.4L 1SC - Red Hot Metallic
2011 Sienna V6 CE - Sky Silver
rollavvti06
i madea diy for nitrous install im still working on it cause i need to do the wiring and feed the nitrous line from the trunk are you runiing a purge kit or are you purging in the motor before launchhttp://www.9thgencorolla.com/f...06043
keithvibe
Re: (rollavvti06)
Post by keithvibe »
Quote, originally posted by rollavvti06 »i madea diy for nitrous install im still working on it cause i need to do the wiring and feed the nitrous line from the trunk are you runiing a purge kit or are you purging in the motor before launchhttp://www.9thgencorolla.com/f...06043saturn purges threw a vent he mounted in his hood.
Mariachi
Post by Mariachi »
interesting thread. I think i know what my next mod is going to be soon
A Psycho Martyr
Re: (mando7744)
Post by A Psycho Martyr »
I always wanted to set something up (co2 for instance) that I could just purge for looks. Like shoot a cloud up my windshield from under my wiper blade kinda pointing out. No nitrous...just purge. Have a switch inside or something.
Mariachi
Post by Mariachi »
if i have it, i would like be able to purge and use it.
