Installing Speakers question
shaeet
Post by shaeet »
I popped off my door panel to install my front components & noticed the stock speakers are enclosed in a plastic housing that is riveted to the door.I had the same exact setup on my Celica & drilled out the rivets, cut out the stock speakers & screwed in aftermarket speakers into the black plastic piece. It was a pain but I was able to mount some pretty deep speakers in there without an issue. The components I have for the vibe are Alpine type-s, not overly deep. How did you guys go about mounting your Front & Rear speakers? And where is the stock tweeter location? I was going to mount them in the triangle mirror trim piece b/c i don't want to drill up my door panel.thx
04 XRS 2ZZ-GE: Injen CAI, hotchkis sways, sportlines on gr2's, brz rims
(Soon For Sale) 05 Vibe 1ZZ auto, 02 WRX Stage 4, 09 VW Jetta Sportwagen TDI
AdmRose
Post by AdmRose »
If you have the Moon and Tunes then the stock tweeters are exactly where you want to mount them - in the sail panel. If you don't then you can still mount them there but it'll be more work.
2004 AWD Vibe - "The Indignant"- Traded in 7/9/12
2010 Honda Insight EX - Current ride
DrunkenMonster
Post by DrunkenMonster »
There is a write-up somewhere let me try and loook.
2005 Vibe Base with M&TKenwood KDC-MP342UAvital 4103 Alarm/Remote StartK&N Panel Air Filter, Removed Silencer, TB Coolant Bypass1998 Jeep Cherokee UKFlowmaster Super 44Cobra 25 LTD CB 2 JL Audio 10W0's / TMA 500
DrunkenMonster
shaeet
Re: (DrunkenDixie)
Post by shaeet »
Um...thx but that thread outlines a crazy custom system where he cut the door panels up and mounted on the outside of em.I'm just wondering how people replaced the OEM speakers with aftermarket in the same oem location. I assume drill out the rivets, drill holes and screw them in? No special mounting kits exist or anything? I'm just worried about the clearance with the windows and all.
AdmRose
Post by AdmRose »
I'd recommend looking on Crutchfield for speakers. If any mounting adapters are required they include them for free.
houseofbugs
Re: (AdmRose)
Post by houseofbugs »
Quote, originally posted by AdmRose »I'd recommend looking on Crutchfield for speakers. If any mounting adapters are required they include them for free.Ditto. I LOVE them. They treat me well. If you call and talk to a sales person there is no annoying upsell.
shaeet
Re: (houseofbugs)
Post by shaeet »
I already have speakers...damn good ones at that....i'm not going to buy more from Crutchfield (which is overpriced btw) Haven't any of you installed speakers in your car? loli guess i'll figure it out, just wanted to know if there were any tricks to it on these cars, thats all.
AdmRose
Re: (shaeet)
Post by AdmRose »
Quote, originally posted by shaeet »I already have speakers...damn good ones at that....i'm not going to buy more from Crutchfield (which is overpriced btw) Haven't any of you installed speakers in your car? loli guess i'll figure it out, just wanted to know if there were any tricks to it on these cars, thats all.Priced at the higher end I'll grant you but when you factor the accessories in that you'd normally have to pay for plus the customer service (which I've never used) it's worth it. That and they don't sell crap.As far as I know there is no great trick to installing speakers in the Vibe. If you want the tweeters in the sail panel just find panel covers from one that had the M&T option.
papacueball
Re: (shaeet)
Post by papacueball »
Dayton RS 180-4 on an adapter I made from a cheap plastic cutting board Sealing up the big holes in the doors will give you better midbass.
2009 Vibe GT - Carbon Gray Metallic - 5 sp. manualClarion-Sundown-Pioneer-Vifa-H Audio-Dayton-SDS
audiovibe
Post by audiovibe »
I like your spacers Papacueball!!!I made MDF spacers but I have some cutting boards that I will be making new brackets out of.The reason crutchfield has to have higher pricing is you keep their authorized status, to stay an authorized retailer the seller can not advertise under the lowest advertised price set by the manufacture.
papacueball
Re: (audiovibe)
Thanks, man. We have crazy humidity and plenty of rain here in Louisiana, so I was kind of leery of using MDF in the doors. I know some people coat their MDF spacers with undercoat, fiberglass resin, or whatever, but I figured it's better to be safe than sorry.
VibeBear
Post by VibeBear »
When I installed my Alpine Type-S 2-way speakers (non component type) I used the mounting plate that came with the speakers. They don't completely seal the holes, but they are sturdy & hold the speakers well. A little bit of silicone would seal up the small gap between the door & bracket
1992 Chevrolet Camaro RS 305/5-speed, Bright Dark Teal
2009 Pontiac Vibe Base 1.8L/5-speed, Carbon Grey
