I've intended on putting lights in the engine bay as well. I want it rigged to turn on when the hood is up and Oznium has a switch for that purpose that I have, just need the lights now lol.
sho looks nice. good job on it.Is there anything you can put on the underside of the hood that is shiny as opposed to the black heat sheild?Like diamons cut steel or something? That would look sweet
looks sweet. i might do that to mine soon. if you are running the 0 to the back of the vibe it will just fit on the driver side under all the trim. Got 0 running to my amp and just fit. passenger side would eazly fit but uses a fue more feet of wire but it will work
yeah, i have it part way run on the passenger side...the optima was just put in about an hour ago so i will finish running it after work tommorow....pictures will be coming of that in a different audio build thread.....i can not wait to show all of you guys my car in person
