Radio's clock constantly resets to 12:00, electrical problem?
big_e
Post by big_e »
The clock built into OEM radio keeps resetting itself to 12:00 randomly. Sometimes it will keep time for several hours after the ignition is switched off, other times only for several minutes. The volume, current radio station, and presets remain unchanged and the radio otherwise works normally. I don't know if the radio itself is defective or there is a loose electrical connection to the radio causing it to loose power.Has anyone else had this problem?
Re: Radio's clock constantly resets to 12:00, electrical problem? (big_e)
welcome to genvibewhat year Vibe do you have, and have you or anyone else you know of takent he radio out before?
If it's a 2003-2008, IIRC the OEM radio will retain all presets and equalizer settings but loses the clock if the constant 12V is lost. (compared to a lot of radios that have to have all settings completely reset.)I suspect you've got an issue with the 12v supply to the radio that should be hot at all times.
Water boy
Post by Water boy »
First thing first...Battery connections clean and solid and tight?Correct water level in battery?
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
106,019 Yokohama YK580 205/55-16 $589.19 drive out
big_e
Re: Radio's clock constantly resets to 12:00, electrical problem? (ColonelPanic)
Post by big_e »
It is a 2003 Vibe. I was suspecting a 12V power issue, but was puzzled that I wasn't losing the presets, like virtually ever other card I owned. The battery is still the original, and probably on its last legs anyways, however according to the original owner the clock didn't work for years. I'll change the battery and see what happens. If not, it will be time to get out the schematics and a voltmeter.
