They have released a service bulletin concerning the center caps falling off the '09 Vibes. 08-03-10-011: Loose orMissing Wheel Cap Repair Procedure - (Aug 22, 2008) The 'fix' is to glue the new ones in, which you MIGHT need to know when you go to get your tires rotated, since they will have to be reglued every time.
Quote, originally posted by tnpartsguy »They have released a service bulletin concerning the center caps falling off the '09 Vibes. 08-03-10-011: Loose orMissing Wheel Cap Repair Procedure - (Aug 22, 2008) The 'fix' is to glue the new ones in, which you MIGHT need to know when you go to get your tires rotated, since they will have to be reglued every time. Why would these need to be re-glued? You don't need to remove to get to the lug nuts...?
03 AWD Neptune, Auto, Moon and TunesTraded 6/30/2008 for09 GT Red Hot Metallic, 5spd auto, sunroof
Quote, originally posted by tnpartsguy »give them the Bulletin # I presented you..... just don't tell them where you got it...I'm on GM's bad list right now anyway.uh-oh, watch out for those black suburbans.
Quote, originally posted by scooter »Why would these need to be re-glued? You don't need to remove to get to the lug nuts...?.........but you do have to remove them to balance the tires, or to mount new tires
Quote, originally posted by DarkVibe »uh-oh, watch out for those black suburbans.Actually, in a GM dealership's case, it's a white 15 passenger van. That's what the audit team rolls in.
Quote, originally posted by tnpartsguy ».........but you do have to remove them to balance the tires, or to mount new tiresVery true.... hopefully they have a permanent fix by the time that's necessary....
Lost 2 caps in about a week on a brand new 09 with the 17 inch wheels that come with the 1sc package. I might write my name/phone number on the back of the other two
Quote, originally posted by Yanner »Lost 2 caps in about a week on a brand new 09 with the 17 inch wheels that come with the 1sc package. I might write my name/phone number on the back of the other two I would love to return a hubcap like that...
Don't know why they need to remove them, but after I took mine in to the dealer to get the tires rotated (no balancing or mounting), ALL of them fell off after 2 weeks.The dealer is refusing to replace them under warranty even after I showed them the service bulletin, claiming it's not a warranty repair (even though the warranty labor code is on the bulletin itself). (removed)?
