how to remove the front passenger folding seat back?
qqleap
Post by qqleap »
i was wondering of anyone knew the easiest way to remove the folding seatback from the front passenger seat. i want to be able to remove it to creat a flat sleeping area to use for camping. when you fold the front seat it is several inches higher than the folded back seat. i don't want to try to remove the seat bottom due to air-bag electronics.
VforVIBE
Re: how to remove the front passenger folding seat back? (qqleap)
Post by VforVIBE »
I thought it went even with the back seats... do you have the front seat folded down correctly?
“I live my life free of compromise, and step into the shadows without complaint or regret.”
Viva la Pontiac! 2009 Jet Black GT
CAN-AWD-VIBE
Post by CAN-AWD-VIBE »
i thought it went flat too. Maybe it is up a little... but im too short to worry about needing more length then the rear cargo area and the seats folded down.i dont think it would be "easy" to take off just the seat back though. easier to remove the entire seat... that left side hinge will be hard to remove if needed. Then you are down like 16 inches though.
VforVIBE
Re: (CAN-AWD-VIBE)
Post by VforVIBE »
It isn't even, well in that case... scrunch up, if your tall, and rest your pillow on it.
Celtic_Curse
Post by Celtic_Curse »
The hard plastic seat back has two standard plastic clips on the bottom...be careful not to break them when you pull up. the top is hinged simular to the trim that is around the stereo, pull down slightly and then tilt up and out. Hope that helps.
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
mathteacher'04vibe
breaking clips
Post by mathteacher'04vibe »
I broke one of the clips you speak of. Unknowingly I ended up spending $70 for the seat back and one new clip (the new back does not come w/clips) Long story short, do not break the clips is right. Pontiac gets $23 each and they (the new ones) are a pain in the rear to pop in place.
'04 Vibe 1.8VVT-i, K&N Typhoon S/R, Fullboar muffler w/3.5" resonator tip. Sony CDX-GT500 h/u + Fosgate mono amp w/2 10" woofers & cap. Tinted side rear windows, SilverStar headlights and Cool Blue fogs. DC Sports Headers. 2.5" stainless pipe from stock resonator to muffler. Limited 903's (17x7.5) Gunmetal Gray with 225/45/R17 Strata tires. Link to my photobucket videos: http://s100.photobucket.com/al...ideos/
waveresponder
Re: breaking clips (mathteacher'04vibe)
Post by waveresponder »
ahhh im going to have to get replacement clips
