Help!Was swapping a blown speaker from the driver's side front and after it was done, power windows and sunroof stopped working. I'm guessing it's a fuse from the box under the steering column but wondering if anyone can confirm this or could it be anything else? If it's a fuse which one would it be.I've heard it's a pain to get at these fuses so I'm hoping to get it right once if I have to go up there!Thx
there is a little plastic cover over the fuses on it there is a diagram of what fuse covers what. pull the cover off and you should be able to tell then. I'm at work so i can't take a pic.
