Where can I find our belt pattern?
Pablo1669
Post by Pablo1669 »
I just replaced all my pulleys with the UR underdrive pulleys, and I don't remember the belt pattern, and can't find pictures of it... can anyone get me a picture of the GT set up if it differs from the Base?
-Brian
ragingfish
Re: Where can I find our belt pattern? (Pablo1669)
Post by ragingfish »
I believe it is located on the underside of the hood...
2009 PONTIAC G8
Pablo1669
Re: Where can I find our belt pattern? (ragingfish)
Post by Pablo1669 »
quote:I believe it is located on the underside of the hood...I can't find it anywhere under, check and see in yours but I definately can't find it. I did see the air hose routing or something like that though
-Brian
cohocarl
Post by cohocarl »
I just tried searching for a pic of a 2zz with a pic of the serpentine belt, but can't find any. There's probably nothing in the owner's manual is there? Some cars have a sticker on the inside of the engine compartment with a diagram of how the belt goes, but I don't remember if the Vibe has one or not.
Pablo1669
Re: Where can I find our belt pattern? (cohocarl)
Post by Pablo1669 »
quote:I just tried searching for a pic of a 2zz with a pic of the serpentine belt, but can't find any. There's probably nothing in the owner's manual is there? Some cars have a sticker on the inside of the engine compartment with a diagram of how the belt goes, but I don't remember if the Vibe has one or not. nothing in the owners manual or under the hood... I tore em both apart tryin to find one
-Brian
NSimkins
Global Moderator
Post by NSimkins »
I saw this in the Service Manual.. the image shows the same for both the 1zz and 2zz... can't verify if they are identical (belt wise) in reality or not.
Pablo1669
Re: Where can I find our belt pattern? (NSimkins)
Post by Pablo1669 »
hey, that worked... too bad I don't have a perfect fit on the belt. Damnit... good find though, tomorrow I'll have the right size belt for sure.
-Brian
ragingfish
You're right, I just checked under the hood, stupid vacuum hose routing diagram. First car I had that DIDN'T have belt routing there...screwy.If you want, I can take pics of my engine belt routing (since I'm all stock on that side) for you to get an idea...lemme know...
2009 PONTIAC G8
